Thread: Heated wing mirrors
    Worcs/Staffs/Westmids (ish)
    Default Heated wing mirrors
    Anyone know which fuse feeds these?
    I've got a Hayne's but it contradicts itself too much on the fuse ID's and locations to be reliable
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    according to the Vauxhall manual there are no fuses that are solely for the wing mirror heated or otherwise. there is one for the door control module (DCM) in Fuse 5 by the glove box but surely if that was duff then more than your mirror would not be working..
    pull the mirror glass off and check to see if the wires are connected.
    VIP-Member Das's Avatar
    Turdsville
    37 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    They operate via the rear demister so have you checked that fuse, its in the rear fuse box, and its #4. I take it you've checked both mirrors are not heating up? As caveman says it could be a faulty mirror.
    ^^ Yeah, what happened was an accident took out the drivers mirror..... I could see the heater element was damaged, pierced and bent.
    It's all been repaired but now the heated mirrors don't work on either side. So I figure the accident took out a fuse and that it'd be a simple fix
    Hayne's manual says F15 or F18 at 7.5amps (if I remember correctly), but on another page it's a 30amp fuse and does a different job, so you can see why I don't trust it lol
    They try to keep it simple, but it's far too simple to be useful :/
  1. heated wing mirrors
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2011, 14:00
  2. wing mirrors!!
    By ross4705 in forum Electrical & ICE (including SatNav)
    Last Post: 7th January 2011, 22:47
  3. Heated wing mirrors
    By Sierra2 in forum Electrical & ICE (including SatNav)
    Last Post: 29th December 2010, 17:47
  4. Wing mirrors
    By L11Marc in forum Electrical & ICE (including SatNav)
    Last Post: 4th December 2009, 23:01
  5. Heated wing-mirrors?????
    By Adamdavi3s in forum Electrical & ICE (including SatNav)
    Last Post: 12th October 2007, 17:00
