Thread: 3.o v6 cdti signum losing power
    Oct 2010
    leeds
    Unhappy 3.o v6 cdti signum losing power
    HELP!! my car has started playing up, it feels like the traction control is taking the power off me or its going in to safe mode, but here are no warning lights, its getting annoying now. Also when idling it sometimes throws a wobbler and sounds like there is a cylinder not firing, sorts itself out, shows me the engine management light for a while and is then fine,I'm confused any suggestions!!!!!!!!!
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by s7uby View Post
    Sounds like it could be the throttle body. I had a 'flat spot' occasionally and typically around the 2,000rpm mark. This also sometimes developed into 'cutting out'. At idle, the rev counter would dip and rise between 300-900rpm for about 2-3seconds. Best thing is to get it plugged to a diagnostic if it had thrown up the fault light.
    Gazza4
    Oct 2010
    leeds
    nice one, come to think of it, it has cut out a couple of times, I just thought it was me being crap!! Its booked in for a service on friday so hopefully will get sorted, do you know how much throttle bodies are??
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Having said that, mines is a 1.9CDTI.
    TB's for the 1.9 150 are £380 but I wouldn't know what a 3.0 would be, but I would wait and see what the diagnostic says m8 if it's going in for a service - ask them to check it for you - will be an additional cost.
    Gazza4
    What mileage is it on?
    Which engine (code) does it have?
    How many miles are left on the service indicator (if on ECOFlex)?
    Sep 2010
    Hartlepool
    Have you tried checking hoses for splits?
    Mainly check vacuum boost hoses and turbo hose. After reading many articles on here about them, it appears that these are the main ones that perish and split.
    I would also check the rest to make sure.
    HTH
    Oct 2010
    leeds
    its got 55000 miles, it does need servicing....in on friday, not sure on engine code, but its the 3.0 v6 cdti 181bhp
    Oct 2010
    leeds
    just picked it up from garage, air filter, fuel filter and oil change and she's a beast again ;-D, must remember not to let service overun again!!!!!
    Culprit was probably the fuel filter
    The service schedule on this item is 20K miles / 30K miles, but clearly they do not last this long (may also lead to debris reaching the SCVs)
    I now replace mine every 10K miles
    Oct 2010
    leeds
    Its done 11k since last service but nearly 14 months........sorry guys!!!!!1
  1. Signum 2.0DTI 2005 Losing Power, Sopunds Like a 1980's Transit
    By Buzzby in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd October 2012, 19:57
  2. 1.9 150 CDTI losing power/boost
    By jay w in forum Engine & Drivetrain
    Last Post: 26th February 2012, 22:57
  3. Losing power*
    By Iezzi-martin in forum Engine & Drivetrain
    Last Post: 27th October 2010, 09:40
  4. Signum 2.2 Direct T Losing Power/Stalling....?
    By Buzzby in forum Engine & Drivetrain
    Last Post: 3rd August 2010, 10:08
  5. Signum losing power all of a sudden
    By Pjuk in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2008, 20:03
vectra v6 cdti cuts power at 2000rpm www.vectra-c.com
