Thread: rear tailgate griffin badge
    Oct 2010
    coatbridge
    Default rear tailgate griffin badge
    Just wondering since im on a mission at the moment de-badging the vectra.
    is the griffin badge on the centre of the tailgate held on with sticky double sided trim tape or is it held on with the rivets,
    want to see what its like removed but frightened in case it leaves two holes in the bootlid lol
    Liverpool
    just stuck on gordon
    i removed mine by pouring boiling water over badge to loosen/melt glue, then prised it off with old necta card
    alot of glue will be left on boot, but it will all pick away
    you may be left with a griffin ghost, bt just a little t-cut or similar will remove this
    dont forget piccys when your done!!
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Yeah man. i used dental floss. worked a treat. then rubbed off the foam with my finger. t-cut then away...
    West
    the best tried & tested way is: use a hair dryer to soften the glue peel the lot off & polish up
    Regular Member Jow20's Avatar
    Sep 2010
    Leeds
    What if its super glued on!?
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Should only be held on with glue, I used hot air gun, then cleaned residue with Autoglym Tar and Bug remover. Tail end shot of mine in "garage" on profile after debadging, if you want to look.
    Oct 2010
    coatbridge
    cool, cheers for the info guys, time to get the heatgun and the panel wipe out lol, wasnt too sure if it was gonna leave 2 holes for the badge to stick on to
  1. For Sale: FREE:rear griffin badge
    By DAVIDD88 in forum Parts for sale
    Last Post: 24th April 2011, 19:59
  2. rear griffin badge
    By triple595 in forum Styling
    Last Post: 19th April 2011, 15:34
  3. New Style Rear Griffin Badge
    By aaruck in forum Styling
    Last Post: 25th February 2009, 14:21
