Thread: Help please, how to adjust the headlights
    Regular Member PeterVV's Avatar
    Oct 2007
    south wales
    Default Help please, how to adjust the headlights
    As I understand it there are two allen key adjustments required. ?.
    1. which one does what.
    2. How do I set them to the correct height/angle etc?
    Since I fitted my HID`s I have noticed the driver side seems to be pointing almost to the kerb! must have nudged it installing the ballasts.
    The passenger side has always seemed to be almost shining on the kerb.
    Regular Member bangty 1's Avatar
    Sep 2010
    in a box
    look ay your lights theres 2 holes on the cross member see them?? you want the 1st hole (im sure thats for up and down) next is left amd right i think lol get a allen key and start twisting your see what they do park next to a wal or up agenst a car and work from there hope i helped
    Full Member spennny's Avatar
    Blantyre
    Sounds like one of the lights has popped out mate ,
    VOTING UKIP IN AVELEY
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    as above ...it maybe that its popped out of the holder..cant see that you could of nudged anything ..
    Oct 2007
    south wales
    Seems pretty solid, no movement in bulb or unit?
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Is it definitely in the holder right, not 90 or 180 degrees out?
    Oct 2007
    south wales
    Just been out and checked, I can move up and down, but not left or right, the bulb is in the holder ok. I may have to re-think the location of the ballast, as I think it is pushing on the end of the bar that moves the one direction axis. Will have to take the air box out again this weekend.
    thanks for the replies.
    Oct 2007
    south wales
    Well, as soon as I got home from work, I was back out taking the airbox out and refitting the ballast so that it now doesnt touch the headlamp or adjustors. Put it all back together , and still left to right doesnt work. I wonder if it was jammed when I turned it and maybe I have taken some thread off it?
    kirriemuir
    mine did,nt look like it moved ether till i turned it a good couple of turn more its deceiving
  1. Handbrake? is it self adjust?
    By dave1419 in forum Vectra C / Signum Car Chat
    Last Post: 17th February 2013, 12:31
  2. facelift headlights dont adjust
    By hairy31 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd October 2012, 18:48
  3. how do i adjust my headlights??
    By bangty 1 in forum Vectra C / Signum Car Chat
    Last Post: 19th October 2010, 16:41
  4. Clock adjust
    By johnny1983 in forum Vectra C / Signum Car Chat
    Last Post: 28th October 2009, 18:12
  5. Is it possible to adjust Auto Headlights
    By tramman in forum Electrical & ICE (including SatNav)
    Last Post: 17th July 2009, 16:59
do vectra headlights self adjust
how to adjust vectra c headlights www.vectra-c.com
