Results 1 to 3 of 3
Thread: Aux/Drive belt tensioner & pulley replacement
    Regular Member Marky's Avatar
    Jun 2006
    North West
    Default Aux/Drive belt tensioner & pulley replacement
    Has any one replaced their drive belt tensioner and upper drive belt idler pulley (the one between the tensioner and the air con)??
    How easy is it?
    Do you have to remove the engine mount?
    Regular Member Craig1985's Avatar
    harwich essex
    If you remove the osf wheel and drop the bottom engine tray you can access everything from there irrc. Had to do this to undo the belt to change alternator.
    Jun 2006
    North West
    Cheers mate, thats what I was hoping.
  1. Drive belt, pulleys and tensioner replacement
    By no1vic in forum Engine & Drivetrain
    Last Post: 13th November 2016, 20:41
  2. drive belt tensioner
    By coooky in forum Engine & Drivetrain
    Last Post: 11th April 2012, 18:19
  3. Timing Belt Replacement -Crank pulley removal
    By alcutler in forum Engine & Drivetrain
    Last Post: 4th April 2012, 19:44
  4. drive belt tensioner
    Last Post: 24th January 2012, 04:14
vectra c drive belt tensioner
vectra c drive belt tensioner how to change
how yo change a drivebelt on vectra c
vectra c 1.9 belt tensioner
vectra c tensioner
vectra c belt pulley
