Thread: dth inlet manifold problems which parts?
    Jan 2010
    Scotland
    Default dth inlet manifold problems which parts?
    looking to replace the inlet manifold on my cdti 150 usual linkage problem.
    anyone advise what the replacement manifold comes as ie is it a complete unit and if so what part no do i need to order? same for the actuator
    anyone know the numbers ?
    cheers
    Jan 2010
    Scotland
    also anyone changed the manifold and used the original actuator? any problems?
    Sep 2010
    Hartlepool
    My inlet manifold was changed a number of weeks ago as a full unit.
    I don't know any part numbers (I think I remember seeing them on a thread on here somewhere) but I hear Vauxhall brought out a modified Inlet manifold.
    I don't personally know the pro's / con's with the revised inlet manifold but I'm sure someone on here will and can advise you better.
    I think most inlet manifolds are changed with a new valve too as main problem seems to be swirl bar becoming detached and the motor underneath it (part of the inlet manifold) wears itself out as a result of this.
    HTH
    Jan 2010
    Scotland
    Anyone change their manifold for a fell off swirl linkage and NOT changed the actuator?
    Regular Member Ollie's Avatar
    Jan 2010
    Towcester
    Engine : 1.9 CDTi (150)
    Mileage : 126000
    You'll be wanting to read this document (Pierburg Service Information docco for intake manifold)....
    Regular Member Hammy's Avatar
    Nov 2007
    Co L'Derry
    Vehicle : Insignia
    Engine : CDTi
    Year : 2010
    funny enough i think i have to change the same and was undecided as to change only the inlet manifold or get the electric Drive module also £200 for the minifold and another £170 ish for the module
    when i take the bar off number 3 swirl thats conected to the module seems to be turning fine back and forth so i might just change the minifold myself
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    The original idea was to change both given most people took notice of manufactures advise as above, I can confirm i have done mine with 1 new manifold & 1 new gasket only, there are more & more doing this now as some of the dealers are doing it too, i would say if the motors working fine then go with just the 2 items, mine is WELL tested 6 1/2 months on and runs Great.
  1. Inlet manifold
    By 1 hammer in forum Diesel Engine related
    Last Post: 29th October 2012, 16:17
  2. new inlet manifold
    By redross555 in forum Vectra C / Signum Car Chat
    Last Post: 10th October 2011, 17:28
  3. 04 cdti 150 New inlet manifold + egr but still problems
    By toodle in forum Engine & Drivetrain
    Last Post: 9th November 2010, 23:51
  4. inlet manifold
    By asty in forum Engine & Drivetrain
    Last Post: 30th January 2010, 19:34
  5. inlet manifold
    By 30ltr nutter in forum Engine & Drivetrain
    Last Post: 27th May 2008, 17:21
