Thread: Someone with tech2 and a facelift car...
    West Yorkshire
    Default Someone with tech2 and a facelift car...
    ...might want to try this.
    Go to the IPC variant config, and in "car type" select "OPC/VXR". Program it, turn the ign off.
    On turning the ign back on, do the needles in the clocks spin round and go back to zero?
    I spotted this setting on my Vauxcom but couldn't get it to program (I am using the latest beta version of the software so this is most likely a bug).
    Regular Member tramman's Avatar
    Selby, North Yorkshire
    Tried it before, doesn't work unfortunately . If only it was that simple.
    If you do have any look with others and different part numbers mine to cross it off your list is 13193088 Ident PF
    spoons
    Guest
    I can tell you that I dont even notice mine doing that any more.... novelty soon wears off
    Even the boost gauge does the needle sweep as well.
    West Yorkshire
    Thanks for the feedback guys. Wonder what the setting is there for then? Can't be anything else surely?
    This has been done on some Astra H's by a bloke going by the name of *****. It needs direct EEPROM programming on that car.
    Spoons - what boost gauge do you have?
    At a guess, like the Astra, the setting will work but only on certain variations of the instrument cluster. Once I set mine (just done it again to confirm) it throughs up two DTC's in the SDM due to loss of communication to CIM and IPC.
  1. Tech2 anybody ?
    By jodiexii in forum Electrical & ICE (including SatNav)
    Last Post: 15th December 2012, 15:41
  2. tech2
    By kenp in forum Vectra C / Signum Car Chat
    Last Post: 17th May 2008, 13:24
  3. Tech2 ?
    By BlueRob in forum Vectra C / Signum Car Chat
    Last Post: 21st September 2007, 09:02
  4. tech2
    By steve.s in forum Electrical & ICE (including SatNav)
    Last Post: 2nd July 2007, 15:36
