Results 1 to 10 of 13
Thread: Fault code P2075 help please
    Regular Member Hammy's Avatar
    Nov 2007
    Co L'Derry
    Vehicle : Insignia
    Engine : CDTi
    Year : 2010
    Default Fault code P2075 help please
    My Vectra 1.9 cdti 150 has the emissions warning light on and car is going into Limp home mode i tried cleaning the egr valve and the Throttle body (both was clogged up a lot) but did not help at all, so i got my m8 that has also a 150 cdti and i tried both his egr valve and throttle body and car is still doing the same tried also his air flow meter
    the car starts and drives ok but light is always on if it goes into limp mode i can turn ignition off and on again the car will rev and go fine for a few mins
    Any help on this be grateful
    ( Edit: swirl flaps seems to be moving ok no signs of any being stuck etc )
    Hammy
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    What about any boost hose leaks? Is there heavy smoke coming out of the car?
    Looking at your profile it's an '07 registered CDTI, does it have a DPF? (To check for DPF - check the door plate and there should be a number - if it's 0.5 you have a DPF and if it's 1.20 you don't have DPF).
    Gazza4
    Nov 2007
    Co L'Derry
    Vehicle : Insignia
    Engine : CDTi
    Year : 2010
    Quote Originally Posted by Gazza4 View Post
    Gazza4
    yes m8 its an 07 reg 150bhp
    checked the door plate and cant see any number of 0.5 did see 1.20 tho and some other numbers chasis number etc
    had a look around the pipes today and did not see anything noticable that would caue any leaks
    car not smoking also
    Bristol
    Vehicle : CDTI 150
    Probably swirl flaps, heres the Vx FR.
    Field Remedy: 2065
    Subject: Engine Z19DTH/ J - Intake manifold, swirl flaps, actuator out of order, DTC: P1109, P2075 set
    Models: Engines: Option:
    Vectra-C 2004...,Signum 2004...,Zafira-B 2005...,Astra-H 2004... Z19DTH,Z19DTH,Z19DTH,Z19DTH| Z19DTJ
    Complaint: Customer complaint about lack of power and SVS lamp on. The following trouble codes might be set based on the installed application: a.) EDC16 C9 (2-actuator strategy, i.e. pressure sensor as well as pressure regulator fitted at fuel rail) TECH 2 shows DTC: P1109. b.) EDC16 C39 (1-actuator strategy, i.e. only pressure sensor fitted at fuel rail). TECH 2 shows DTC: P2075.
    Cause: Problem might be caused due to sticking swirl flap or due to malfunction from swirl flap actuator.
    Production: Several modifications introduced since SOP. Latest improvement was a design change at the swirl flaps itself in order to make the flaps more robust and to prevent them from sticking. Engine-BP: Z19DTH17228334 (28.02.2007).
    Remedy:
    In case of customer complaint perform TECH 2 swirl flap actuator test
    in order to evaluate the problem.
    Recommendation:
    Remove upper beauty cover in order to see the swirl flap linkage
    mechanism. Switch on ignition (no need to start the engine) take
    TECH 2 out of the vehicle to the engine bay. Change into swirl flap
    actuator test and perform test. If linkage does not move at all but
    the actuator motor itself is working (audible) it might be that:
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    From this site:
    http://www.3800pro.com/lists/obd2codes.html
    I found this:
    P2075 Intake Manifold Tuning (IMT) Valve Position Sensor/Switch Circuit
    Gazza4
    Nov 2007
    Co L'Derry
    Vehicle : Insignia
    Engine : CDTi
    Year : 2010
    weres this Valve Position Sensor/Switch Circuit is it part of the manifold ?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by Hammy View Post
    Not 100% sure, but I would say it's part of the drive module - which is inaccessable unless you take the manifold out, which is a pain. The drive module sits under manifold, directly under swirl flap no 3.
    Nov 2007
    Co L'Derry
    Vehicle : Insignia
    Engine : CDTi
    Year : 2010
    looking at the inlet manifold i noticed that one of the swirl valve things is sitting higher then the rest when i spryed a little WD 40 at it i noticed its releasing some air
    could this be the problem ?
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    If there all moving it shouldn't be the problem, could be a actuator motor problem or as said position sensor, but not sure where the sensor is located, it could be in the motor housing?, by the way i would also clean the boost sensor if you haven't done so already.
    Nov 2007
    Co L'Derry
    Vehicle : Insignia
    Engine : CDTi
    Year : 2010
    Quote Originally Posted by the-wizard View Post
    the last one seems to be able to move around 360% very easy rest seems to only want to move so far in each direction
    cleaned boost sensor too
  1. P2075 code
    By carl78 in forum Engine & Drivetrain
    Last Post: 25th July 2012, 19:16
  2. Fault code help :(
    By Thom in forum Electrical & ICE (including SatNav)
    Last Post: 4th February 2012, 20:14
  3. fault code help
    By delboy2028 in forum Vectra C / Signum Car Chat
    Last Post: 21st March 2011, 21:16
  4. Fault Code?
    By CDTi-SRi-Matt in forum Vectra C / Signum Car Chat
    Last Post: 26th February 2009, 21:43
  5. Fault Code?
    By CDTi-SRi-Matt in forum Electrical & ICE (including SatNav)
    Last Post: 26th February 2009, 21:23
p2075
p2075 vectra
p2075 opel
OPEL P2075
fault code p2075
p2075 vauxhall
p2075 vectra c
p2075 fault code
zafira fault code P2075
Opel DTC P2075-61
signum cdti 150 p2075
Vauxhall P2075vectra p2075zafira B 1.9 CDTI code erreur P2075what does the angine cod p2075 mean on vectra 19 dieslevectra c swirl flap codesp2075 p0660 vauxhall zafira 2007vectra fault code p2075vauxhall vectra sri cdti fault codesvauxhall error code p2075troubleshooting engine code p2075vauxhall fault code p2075vectra cdti p2075vectra cdti p2075 intake position sensorvectra fault code 2075
