Thread: How long do glow plugs normally take to heat?
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Default How long do glow plugs normally take to heat?
    Evening all.
    I always knew something was missing from the dash. Couldn't put my finger on it but have finally twigged onto it being the glow plug light. Now as winter is setting in, I'm starting to wonder how long glow plugs take to heat roughly seen as I can hear more than one relay clicking from outside so can't tell that way when they're on or off.
    I'm thinking about 4 seconds?
    Don't want to shell out for new clocks just for a duff bulb!
    Liverpool
    Mine take literally 2 seconds
    Only way you will know is in winter when they take slightly longer, plus if it is an led that has blown, it will cost pence to replace
    I wouldn't worry about it unless you have trouble starting on the very cold days. I believe they don't come on till the temperature drops to under 5 degrees anyway...
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    You will see the light only quickly! most people think that's it! NO!!, Thats only an indication to let you know there working, The plug will heat for example 6 seconds at 11v & then a further 6 at 6v, this is common practice with most diesels for the plug to be heating for that amount or more.
    Jul 2010
    rotherham
    MY light has come on once since i have owned my vectra, about 3 months. When i start my car white smoke comes out of the exhaust when it is cold and my car seems to like struggle so im thinking its the glow plugs but going to get it on the computer first just to make sure. Mayaswell change them now instead of waiting till it is about 2 degrees.
    lanark
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    my glow plug light has come on all through the summer for about 2 secs and it's still the same just now and we have had frost a couple of times already
    Regular Member bigdave1701's Avatar
    York
    I saw my glow plug light for about 5 seconds last winter.
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Mine comes on for a few seconds if car/weather cold. Was one of the things I struggled with, being my first diesel, remembering to look lol.
    Aug 2010
    Antrim
    Can't say I have noticed, but the CDTi is noticably slower to start than either my Mondeo TDDi or TDCi's were. The Fords always started instantly, where as the started always has to chug for a second or two in the Vectra. Was the same in my fathers diesel Cavalier.
    Regular Member congaman's Avatar
    Sep 2010
    UK
    Mine has only flashed on once on a damp morning for about 2 seconds!
  1. glow plug heat up time Q ?
    By bembo449 in forum Engine & Drivetrain
    Last Post: 13th May 2011, 13:06
  2. How long to heat up?
    By woodspsx1 in forum Engine & Drivetrain
    Last Post: 31st January 2011, 08:11
  3. Glow Plugs
    By fattony in forum Vectra C / Signum Car Chat
    Last Post: 2nd October 2010, 20:26
  4. glow plug relay and glow plugs
    By bobk1 in forum Engine & Drivetrain
    Last Post: 3rd September 2009, 17:02
  5. How Long to heat Up for a 1.9CDTi?
    By boba in forum Vectra C / Signum Car Chat
    Last Post: 10th November 2008, 20:22
how long do vectra c glow plugs last
