Likes Likes:  3
Results 1 to 10 of 23
Thread: Insignia washer jets on vectra
    Regular Member Jow20's Avatar
    Sep 2010
    Leeds
    Default Insignia washer jets on vectra
    What is this mod people keep talkin about? What does it do/ look like etc..?
    Aug 2010
    Stoke on Trent
    they look identical to standard washers but they produce a wide spray/mist over a wide windscreen area rather than a jet of water.
    Regular Member Hyperhart's Avatar
    Jan 2010
    Luton, Bedfordshire
    Vehicle : Astra GTC VXR
    Trim : VXR
    Engine : 2.0t
    Instead of having 2 streams of water coming out of the washer jets it sprays it over the windscreen due the fan design.
    Not that easy to adjust though.
    South West
    Very easy and cheap mod to do. The standard washer jets are two nozzles which put two jets of water onto the windscreen. The new insigna ones spray a fan of water on the window and are much more effective.
    Mod takes about 15 mins to do. Might need to adjust them once fitted, but mine were perfect without any adjustments.
    Look in the How2 section for a complete step by step guide to fit them.
    Rgds
    Aidi
    Sep 2010
    Leeds
    Not summet to loose sleep over then! I never even use jets anyway so ill forget that mod! Lol
    Regular Member @ndy-e's Avatar
    Warrington
    Quote Originally Posted by Hyperhart View Post
    A bit dear mind, but can buy this! Though Im sure there's an hoe 2 somewhere with a custome made pen lid to adjust it!
    Regular Member kentish_bloke's Avatar
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    got my insignia washer jets off ebay for around £5 for the pair & fitted them in a few minutes with help from a kettle full of hot water.
    mine havent needed adjusting, so no adjusting tool needed
    VIP-Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 Vtec
    Mileage : 64500
    Quote Originally Posted by Jow20 View Post
    Silly question but how do you clear your screen in winter when your driving?
    Quote Originally Posted by kentish_bloke View Post
    Neither did mine when I fitted them, but now 1 points high and one points low, ive checked they are still seated properly(and they are) so ive ordered an adjusting tool from ebay.
    london
    Fitted my Insignia Washer Jets but Now i'm having problem adjusting it ...the Passenger side needs adjusting. I thought the design is meant to be cutting edge .
    Jan 2010
    York
    Thumbs up
    Quote Originally Posted by pinnacare View Post
    Yeah - but they're INSIGNIA washers..................
  1. insignia washer jets
    By rozzer2006 in forum Styling
    Last Post: 29th January 2013, 14:58
  2. Insignia Washer Jets
    By Paul_NI in forum Vectra C / Signum Car Chat
    Last Post: 5th April 2012, 14:29
  3. Insignia Washer Jets
    By Lean6 in forum Vectra C / Signum Car Chat
    Last Post: 31st August 2011, 20:42
  4. Insignia washer jets
    By 19CDTi in forum Vectra C / Signum Car Chat
    Last Post: 17th January 2010, 17:07
vectra c insignia washer jets
are insignia washer jets much better than vectras
vectra c fitting insignia washer jets
how to fit jet washers in vectra
insignia washer adjuster pen lid
vectra c washer jets on ebay
changing vectra c washer jets
insignia washer jets vectra
vectra c washer jet upgrade
how to get waaher jets off vectra c
change vectra c washer jets
insignia washers
vectra insigma washer jets
electric wires on washer jets vectra c
insignia washer jets vectra c
insignia washer jet vectra
