Thread: Are HID`s supposed to make a noise?
    Regular Member PeterVV's Avatar
    Oct 2007
    south wales
    Default Are HID`s supposed to make a noise?
    Tried them out tonight for the first time in the dark, well impressed, at least twice as bright as bulbs, when I tried them with the engine off, I could hear a high pitched whine coming from them, is this normal?
    Also the flash once , then warm up when switched on?????
    driver side doesnt seem as bright as the passenger side, and may need adjusting, is there a how to align the beam at the correct height?
    Dunstable
    The high pitch noise is the ballast. It has to generate an extremely high voltage to illuminate the gas inside the bulb, it usually gets quiet after it's warmed up. And yes, they flash, then get brighter gradually. Again it's to do with the type of bulb
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    Full Member paul.sessions's Avatar
    leighton buzzard
    Regular Member fingers66's Avatar
    Carpe Diem
    Sodding Typical on Sea
    Quote Originally Posted by PeterVV View Post
    The drivers side reflector seems a bit different in design to passenger side as the beam patterns are a slightly different shape I notice that too the bulb is as intense but the spread pattern is quite different, was the same on H7's just harder to notice
    Regular Member Jezzy's Avatar
    S.E
    Mine don't make any noise.
    Full Member gibbon7000's Avatar
    lincs
    My other car. 1972 1641cc slammed beetle. On the road finally!!
    West Yorkshire
    Mine make a bit of noise while warming up.
    If they are flashing, or one is brighter than the other etc. I would get the UEC reprogrammed to tell it that the car has xenons fitted. This sorts out a lot of problems people have with HIDs.
  1. was supposed to buy an engine but...
    By IDVAC in forum Vectra C / Signum Car Chat
    Last Post: 5th April 2012, 18:21
  2. Can EGR Valve make a noise?
    By justin32 in forum Engine & Drivetrain
    Last Post: 31st March 2012, 09:57
  3. is oil supposed to be here?
    By G19RKE in forum Vectra C / Signum Troubleshooting
    Last Post: 7th March 2012, 23:41
  4. Not Sure if it's supposed to be doing this???
    By Warrenmole in forum Engine & Drivetrain
    Last Post: 28th August 2008, 20:42
  5. Replies: 2
    Last Post: 19th December 2006, 23:49
