Results 1 to 10 of 22
Thread: Central Heating Help
    Regular Member Exclusive BV's Avatar
    West Midlands
    Default Central Heating Help
    I noted with interest that there were a few central heating engineers on the site and I was wondering if any of you could give me some advice.
    I have a worcester combi 28 cdi and 10 radiators in my 3 bed semi.
    I have a problem with the big double rad in the front room. It only gets hot at the top and the bottom is cool so it's probably sludged up.
    Ideally I would like a powerflush but there are two things stopping me.
    1. I got quoted £400 from a local firm.
    2. The other rads seem fine.
    The way I see it, there are two possible options.
    Either....
    A) Take the double rad off the wall and blast the rubbish out
    or
    B) Use Sentinel x.400 in the system for a few weeks followed by a flush and then refill with x.100 rust inhibitor.
    What do you guys think is best?
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    I would take it off the wall and try flushing it yourself. I haven't ever used any of the chemicals so i wouldn't like to say if they are any good
    Slough
    60 Post(s)
    Vehicle : insignia vxr
    Trim : vxr
    Engine : 2.8 turbo
    Year : 61
    Mileage : 38000
    i would take it off and flush it out not a very hard job to do . khalid
    . irmy door pins, pedals,chrome /elec folding mirrors covers.parking sensors/ window tints all round.blue led dash conversion.debaged /k+n filter twin mij cat back exhaust . xp front spoiler and irmy boot spoiler .b8,s and H+ R springs. afl, headlights
    Oct 2009
    bolton
    do not use any chemicals!! your boiler will start to leak within hours it will attack o rings etc, take rad of wall and flush out while its of flush each leg valve open into a bucket with filling loop fully open, power flushing is a waste of money
    Regular Member Dazzy2006's Avatar
    Notts
    Sorry to hijack your thread but do any of u central heating boffins do exercisms on boilers cos my central heating has decided to turn itself on even though its switched off at the timer and the thermostat is on 0 its still on
    I've turned it off at the boiler but thats only a temporary fix
    Regular Member Das's Avatar
    Here
    35 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Flushing them out is a piece of pee pee tbh, did all mine myself last year.
    The Wife's just off the phone to Scottish Gas as our boiler has stopped working tonight, thank heavens for their home care plan, their coming out tomorrow.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Remove the rad and flush it.
    It may be that other rads need turning down to balance the system so you get good flow through all rads.
    I would also flush the main circuit by opening the rad feeds and letting some water drain off. A garden hose works, and a standard exterior tap screw fitting fits the rad fitting - enabling the hose to be run out to an external drain. You will be surprised how much black gunky water will come out if you don't have inhibitor in the system and it's been left a few years....
    Then refit the rad and bleed.
    Maybe flushing all the downstairs rads would be good idea.
    How long do other rads take to warm up? Is the de-aerator blocked up?
    When we moved into our current house, it was clear that the CH system had been ignored and neglected for a few years. A few bangs on the de-aerator dislogded a lot of carp which then went into the circulating water. I flushed all the downstairs rads and the circuit and refilled. Now working better than it's ever done.
    West Midlands
    thanks very much for the replies, Where can I find the de-aerator?
    I am now leaning towards removing all downstairs rads and flushing out as the ones upstairs tend to be much hotter.
    Also I have two downstairs rads with drain valves fitted, I have one in the kitchen and one in the hallway. When I drain the system do I open both?
    Any CH Engineers care to write me a how to?
    I know there's probably not a lot to go wrong but how many times should I refill and drain the system afterwards before I put in the rust inhibitor?
    Here
    35 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Quote Originally Posted by Exclusive BV View Post
    Open the one that is the lowest, then open the bleed valve on the highest radiator in the house(often the bathroom). You need to open the bleed valve to release the vacuum to allow the water to flow.
    Id just refill and empty(and repeat) it untill its runs clear.
    West Midlands
    There is not much to seperate them tbh, both valves are about 1.5 inches from the floor.
    So let me get this right in my head.
    1. Fit hosepipe to lowest downstairs rad and open valve
    2. Open bleed valve on highest upstairs rad (to equalise pressure I presume)
    3. Drain system
    4. Remove affected rads, blast clean and refit
    5. Refill system and drain until clear
    6. Fill to manufacturers settings and load up with inhibitor
    Is this right?
  1. Central Heating problems
    By phil67 in forum The 'Off Topic' room
    Last Post: 9th April 2012, 21:04
  2. Power Flushing - Central Heating
    By spoons in forum General Chat
    Last Post: 18th August 2011, 12:25
  3. Oil fired central heating - bunded tank
    By Ste in forum The 'Off Topic' room
    Last Post: 16th December 2009, 22:52
  4. new central heating radiator
    By garvey in forum The 'Off Topic' room
    Last Post: 5th February 2009, 21:33
  5. sludge in central heating system
    By moorlander in forum The 'Off Topic' room
    Last Post: 27th September 2008, 08:06
