Thread: Alternator or Battery?
    Yorkshire
    Default Alternator or Battery?
    The car died today. Got it started via jump leads and checked the voltage (11.49), when revving the engine, this would raise to approx 11.85.
    I did the headlight test (see if the headlight dims or brightens when revving) and the lights stayed bright throught.
    I then did a test by removing the Positive cable with the engine running. The car stalled when this happened. The car however would stay alive if being revved once the terminal was removed.
    Any ideas?
    P.S - Once jump started, the car got me home approx 20 miles away.. and even then I could turn off and start the car 3 times.
    Ely, Cambridgeshire
    60 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Sounds like your alternator is definitely on the way out. It should charge at about 12.8v minimum and up to 13.8 unloaded. Look like it's still giving enough to just keep most things running but it wont for long.
    Yorkshire
    Damn :/
    Is there any sure way to check?
    Also.. would a Alternator from a Vectra C 2.0 DTI (2003) fit my Vectra C 1.9 CDTI? (55Reg Diesel).
    Thanks.
    Regular Member Dazzy2006's Avatar
    Notts
    as ian says the alternator should be between 13 - 14 volts when engine running and i doubt a dti alternator would fit
    Local autofactors will usually test it for free
    Maybe breakers yard or reconditioned 1
    Ely, Cambridgeshire
    60 Post(s)
    Year : 2010
    Had the alternator fail on my other Vec about two weeks ago (just as I was trying to sell the car as well). Cost me £160 from Halfords after the exchange refund.
    Jan 2010
    glasgow
    as u have done the volts test did u try heaters on lites on all alectrics on in the car then do the test ie with a full electical load on the alt
    Yorkshire
    Quote Originally Posted by hoochydady View Post
    Just the lights. The car would stay on while revving but would die shortly after releasing the rev's.
  1. battery or alternator?
    By Swedge in forum Electrical & ICE (including SatNav)
    Last Post: 23rd August 2012, 08:33
  2. Alternator or Battery
    By Jamie in forum Electrical & ICE (including SatNav)
    Last Post: 21st December 2011, 21:30
  3. Help With Battery/Alternator
    By Ultim8 in forum Electrical & ICE (including SatNav)
    Last Post: 27th May 2011, 14:37
  4. Battery, alternator or something else?
    By djr69uk in forum Vectra C / Signum Car Chat
    Last Post: 6th December 2010, 16:19
  5. Alternator or battery?
    By RobW in forum Electrical & ICE (including SatNav)
    Last Post: 29th November 2010, 22:20
