Thread: Engine Starting 1.9CDTI 150
    Sep 2010
    Default Engine Starting 1.9CDTI 150
    As this is my first deisel, I'm wondering if all CDTI 150's have a smal shake when they start, as my brothers Audi 1.9TDI doesn't and my partners Toyota 2.2 T4D doesn't,.... wondering if it's normal
    West
    Explain the shake?
    Sep 2010
    Well,.. it's when the engine fires up, it shakes the car, but once running it's fine - can't explain it any further than that really (I know the engine is an old design so maybe it's just not as refined as Toyota or Audi (even tho it does more mpg!!)
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Check if the swirl bar has fell off!, its a common thing for the shake symptom to be this, there's a how 2 for repairing if this is the case, 2nd point would be a glow plug but there's usually a fault light with this.
    Sep 2010
    thanks .. will check these
    Bristol
    Vehicle : CDTI 150
    CDTIs can have a rough initial idle due to load on the alternator. Vx did have a field remedy out for this.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    I have a dodgy throttle actuator and I occasionally get this - whether the two are related I'm not 100% but I know if the flap is not functioning properly it can cause a 'shake' on switch off of the engine.
    Gazza4
  1. starting issues 1.9CDTi 8v
    By Kevinw29 in forum Engine & Drivetrain
    Last Post: 14th October 2011, 08:10
  2. 1.9CDTI Starting Problem..it just clicks once
    By Grippy in forum Engine & Drivetrain
    Last Post: 4th August 2011, 20:27
  3. 1.9cdti whine when starting
    By mann3210 in forum Engine & Drivetrain
    Last Post: 12th July 2011, 12:16
  4. starting problems 1.9cdti 8v
    By Turbomanrony in forum Engine & Drivetrain
    Last Post: 8th November 2010, 02:36
  5. 1.9CDTi starting problems
    By 3961bobking in forum Introduce yourself.
    Last Post: 7th June 2010, 09:26
