Thread: loud turbo hissing, hole in intercooler pipe maybe???
    Oct 2010
    south shields
    Default loud turbo hissing, hole in intercooler pipe maybe???
    ive noticed my vectra i just bought (wish i didnt now!) the turbo is hissing loud when i rev like a dump valve sort of, and when i come off the accelerator i feel quite a clunk, thinking it may be a hole in the intercooler pipe causing loss of pressure... and one of the big pipes coming off my engine is actually taped up with electrician tape!!! but looks pretty air tight... hmm any ideas people
    West
    What endine is it?
    Best bet is to get someone to hold the revs down while you have a look around the hoses, any leaks will be easy to spot
    Sep 2010
    Hartlepool
    Try checking your turbo pipe (large one at right side between engine and battery compartment) for splits / perishing.
    If you have problems with your car driving too, also check your boost vacuum hoses at the front of your engine.
    Regular Member kamar's Avatar
    bradford
    i had a bora that did this and it smoked alot but my intercoller was leaking.
    but on my vec my turbo is loud and whistles... but ive had it cheked all ok...
    Oct 2010
    south shields
    its the 2.2 dti engine mate, and ive done tht looked around whilst revving the engine cant really spot anything.. do u think the clunk when i release the revs is related to this??
    bradford
    oh ok the turbo pipes are abit common on them
    Regular Member Dazzy2006's Avatar
    Notts
    Have to taken the plastic engine cover off?
    The intercooler pipe on the left that runs across the top of the engine seems to fail alot - mine had the same symptoms as yours and the intercooler pipe had a large split underneath
    Regular Member Innes's Avatar
    Plymouth
    Definalty a hole in one of the inter cooler pipes mate. I had the exact same thing. I coundt believe the noise it made! I bodged a repair whilst I waited for my sspare bits to arrive. Lasted about a week then it sounded like a fart from a baloon! If its the right hand pipe check out my repair for £30:
    http://www.vectra-c.com/forum/showthread.php?t=116528
    Oct 2010
    south shields
    nice one mate, would do all that if i find out where its coming from...
    Plymouth
    Best thing to do is is take the plastic cover off the engine and check all the intercooler hoses marked in purple below.If the covers on its really hard to detect where its coming from. If your pipes got tape around it then thats the most likely place to start. When you floor the acclerator theres a lot of pressure going through that hose and it expands and thats when its probably getting around the tape. You need someone to rev the car whilst you have a look.
    If you dont want to make our own replacment you fet silicone replacement from ebay for both sides:
    http://cgi.ebay.co.uk/Vectra-C-Turbo...item3cb0f6ce5b
    http://cgi.ebay.co.uk/Vectra-C-turbo...item3a5ea9fa4b
    Vauxhall sel lthe whole intercooler pipe set for £120. They dont sell pipes seperatly.
  1. Very loud hissing
    By Micky86 in forum Engine & Drivetrain
    Last Post: 14th February 2013, 13:58
  2. Replies: 117
    Last Post: 8th November 2012, 15:03
  3. Turbo to intercooler pipe
    By johnnyboy1985 in forum Vectra C / Signum Car Chat
    Last Post: 13th March 2011, 21:14
  4. Now that's what you call a hole! (turbo pipe)
    By 123ashleyp in forum Vectra C / Signum Car Chat
    Last Post: 27th July 2010, 20:00
03 vectra c turbo pipe hissing
vectra intercooler turbo hose
vectra c intercooler pipe
turbo hose vectra c
hole in intercooler hose
vauxhall insignia loud turbo
loud winey turbo vauxhall insignia
hole in intercooler a3
vectra intercooler turbo hose site:www.vectra-c.com
