Results 1 to 10 of 18
Thread: Understeer and spinning wheels.
    Chelmsford
    Default Understeer and spinning wheels.
    Was driving a little "enthusiastically" the other day and on a couple of roundabouts noticed the car (04 plate hatchback) seemed to be understeering a little more than I remembered and felt a little unstable.
    Also noticed that it now seems easier than before to spin the wheels when pulling away, especially in the damp (no TC on my car, although it's only a 1.8 petrol so not exactly overpowered!)
    Front tyres are Michelins, with about half their original tread. New Kumhos on the back, might swap them over when I get back home.
    Just wondered if the problem could be due to worn suspension components. Already had the classic busted coil spring problem on the rear, so wondered if it had happened on the front. Can't see any obvious problem (although not got a jack here) and the car seems to be sitting level. One thing I did notice was it seemed to "bounce" a little oddly when I shoved down on the nearside wing a couple of times.
    Going to get a garage to take a look, just thought I'd try here first. Any ideas chaps?
    Cheers.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    If it's bouncing excessivly when pushing down a corner it would point to a knackered shock absorber
    Aug 2009
    Bradford
    God has overnight remapped your car :P
    No idea mate, I have that problem too but that's due to me being a lunatic and after chipping the car. I doubt its suspension problem or tyre, possible you accelerating at the rate you never did before? ie using the full power now?
    Regular Member djr69uk's Avatar
    Midlands
    a shock in working order will return to its normal position but should not bounce about before it does - if it does it indicates that the shock could be cream crackered! if the shock is gone then it can force the wheel to bounce about excessively on the road and lose a bit of traction - hence you might be getting understeer due to it. might be worth taking to kwik fit or somewhere and getting them to 'diagnose' the problem FOC
    Full Member Big Sig's Avatar
    Quote Originally Posted by djr69uk View Post
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    you'll come out needing new rear pads and discs and a new exhaust and still have the problem of a knackered shock
    Midlands
    woah woah woah lol!! don't misunderstand me guys lol!!! I wouldn't let those MUPPETS work on my car ever!! However, I would let them chuck it on a ramp, spend an hour going over every inch of it finding out what's wrong (and then trying to find something else to sell me) on the hope that they might get a booking... ignore all that though... just take diagnosed problem and get what needs doing done elsewhere - or DIY it. Simples!
    woah woah woah lol!! don't misunderstand me guys lol!!! I wouldn't let those MUPPETS work on my car ever!! However, I would let them chuck it on a ramp, spend an hour going over every inch of it finding out what's wrong and then trying to find something else to sell me on the hope that they might get a booking out of me... ignore all that though... just take diagnosed problem and get what needs doing done elsewhere - or DIY it. Simples!
    Completely understand, just after all the faults they missed on watchdog I doubt they would even find it, they are ****** useless
    Chelmsford
    Just had it into a local suspension specialist, surprise surprise, offside coil spring busted...
    Time to get the Haynes out... Anyone any idea how hard the job is? Did the rears a few months ago with no probs.
    Regular Member Jezzy's Avatar
    S.E
    The problem with using Kwik Fit to check your shocks is that you can't trust them not to spray wd40 on them and claim that the shock is leaking, even if in reality the shock is fine.
  1. Wow massive understeer.
    By crespo in forum Vectra C / Signum Car Chat
    Last Post: 8th May 2010, 14:08
  2. TC ESP kicks in even when wheels arent spinning?
    By n_hudson in forum Engine & Drivetrain
    Last Post: 6th May 2010, 17:11
  3. Front wheels spinning
    By Mazzy in forum Handling & Braking
    Last Post: 12th December 2008, 14:53
  4. understeer ?
    By deg in forum Vectra C / Signum Car Chat
    Last Post: 12th September 2008, 23:35
  5. Understeer on SRi
    By Penfold in forum Suspension, Wheels & Brakes
    Last Post: 31st December 2007, 20:52
