Thread: Doh! Bonnet Cable!
    Regular Member @ndy-e's Avatar
    Warrington
    Unhappy Doh! Bonnet Cable!
    Went to open the bonnet today and the cable handle just came out in my hand, does the cable look its broken if its out this far?
    Or will I be able to open with pliers and someone on the bonnet method? I really dont fancy wrecking the grill or having to struggle getting the bumper off like Ive seen in threads I found when searching!
    Regular Member madman's Avatar
    nottm
    dont bother messing with the grill. get the car up on a lift , remove the bottom engine cover and you can reach thru with a metal bar/rod and flick the bonnet release latch. mine was done and the cable readjusted for 1 hrs labour at a local garage. £25
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    The cable might only be needing adjusted
    Hanging Heaton
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    Grab the wire loosely with pliers opposite side of the handle, and pull the handle... Will that not work if the pliers then force the plastic sheath back?
    Warrington
    Quote Originally Posted by madman View Post
    Cheera fellas I will probably go for that option as the local garage I use aint too bad, Im off next Mon and Tues so will get it done then!
    West London
    did you get this sorted? same thing happened to me today, managed to get the bonnet opening from underneath the car - now works on the cable if i hold the black sheath and pull the silver cable. dont wanna mess around to much in terms of putting the interior housing back in as im scared of the bonnet getting stuck again.
    Warrington
    The cable had come off the bonnet end so had to take it a garage, he ended up having to take the bumper off to open it! But he refitted the cable and adjusted it all for me.
    Cumbria
    I've just done mine today and followed your instructions (ta very much), I took the belly pan off, and I could reach up past the fans and push the spring end with my thumb. On a DTi there is no need to break anything or remove the grills/bumper. The cable had come loose because it was too slack. Just wish I'd adjusted it before.
  1. bonnet release cable,,,AGAIN!!!!!
    By collyb in forum Bodywork & Interior
    Last Post: 25th June 2012, 08:49
  2. bonnet release cable
    By eminemme42 in forum Vectra C / Signum Car Chat
    Last Post: 19th January 2012, 15:17
  3. Bonnet release cable.
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 19th December 2010, 10:18
  4. how u open bonnet without cable lol
    By marc7 in forum Vectra C / Signum Car Chat
    Last Post: 14th October 2009, 20:31
  5. bonnet cable
    By selv1980 in forum Vectra C / Signum Car Chat
    Last Post: 28th June 2007, 08:56
