Thread: Car/Spanner light
    Aug 2010
    Blackwood
    Default Car/Spanner light
    hi guys,
    cars just out of warranty & the car/spanner light comes on.
    has only come on once when just starting the car but the otehr 3 or 4 times its been while driving.
    normally goes out after about 20seconds or if i switch the engine off or if im slowing down??
    when its on, car goes into limp mode.
    ive tried the pedal trick but no joy.
    is this light just a generic warning light or does it mean a specific area?
    im hoping its just something simple & cheap to fix.
    thanks guys
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    DTi?
    Aug 2010
    Blackwood
    yeah 2.0 dti, 2004 hacthback.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Check the two large boost pipes for splits, check all of the vacuum pipes for cracker rubbers ends give egr valve and boost sensors a clean
    Aug 2010
    Blackwood
    cheers. ill get my mate to check them out. i know nothing about engines.
    Aug 2010
    Blackwood
    cars going back to garage tomorrow to have the fault read. the engine managment light is now staying on too & cars in "limp mode". any ideas?
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Anything from boost sensor , egr needing cleaning ,split vacuum hose connectors to split turbo hoses anyone of those will give you your symptoms. The good news is all are easily fixed once you know in what direction to head ,
    Get the garage to give you a list of all the fault codes generated then post them on here we should then be able to steer you in the right direction and not into the bottom of a stealers pocket.
    Aug 2010
    Blackwood
    cheers. its the garage where i bought it from, luckily enough though the 3mth warranty runs out tomorrow.
    ill ask him for the codes & post on here to help anyone else out who's gotthe same problem
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Problems with Air bag light, ABS, Anti Skid & Spanner light
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 21:23
  3. Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 18th August 2012, 11:57
  4. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  5. spanner light then engine management light
    By learoy69 in forum Engine & Drivetrain
    Last Post: 12th March 2010, 20:10
