Thread: RPM LCD Display Blank
    Sep 2010
    Dorset
    Default RPM LCD Display Blank
    Hi,
    I have just acquired a Vectra C 2005 1.9 CDTI SRi 8V. The small LCD display in the RPM dial is not displaying any data although the backlight leds change from amber to red. I suspect it may have had its data stream nobbled somewhere by bodgers in the past trying to hide issues the car had eg tailgate locking sensor / switch missing.
    All the other functions of the instrument panel work OK. I have had the clocks out, but cannot find anything amiss. Tech2 does not help as far as I have been able to ascertain.
    Anyone any ideas?
    Thanks in advance
    Ian
    West Yorkshire
    The ribbon that connects the mileage display to the instrument panel PCB is very fragile. Once broken, there is no obvious way of fixing it, and the only solution is to get another set of clocks.
    Have you checked this ribbon to see if it's okay?
    Sep 2010
    Dorset
    The mileage display is working ok. Its just the info display in the RPM dial that is blank.
    West Yorkshire
    Quote Originally Posted by id90288 View Post
    Sorry, didn't read it properly. That one is held to the circuit board in the same way. Have a look to see if the ribbon is damaged.
    At some point Vauxhall changed what was displayed in this screen and kept it more basic for certain warnings and the autobox. For instance, gone is the door / boot opening symbol - replaced for a light elsewhere in the instrument cluster.
    Are you sure it's just not displaying anything because there are no current warning messages?
    Sep 2010
    Dorset
    Not seen any other warning lights on instrument panel to indicate doors open or anything. From last Vectra C I had (54 Plate 3.0 V6 Diesel) all the door/tailgate warnings were displaced in this LCD.
    (My current Vectra is not a facelift)
    Regular Member Dazzy2006's Avatar
    Notts
    Easy to test - pull a bulb out and see if it shows a fault in the display
  1. Where can I get an EGR blank for a 2.2 Vec C?
    By Partyvan in forum Petrol Engine related
    Last Post: 5th January 2011, 21:52
  2. temp display on radio display
    By MRunMotorsport in forum Electrical & ICE (including SatNav)
    Last Post: 19th April 2010, 15:55
  3. blank dvd
    By pyro_maniac in forum Games Room
    Last Post: 1st January 2009, 22:17
  4. blank egr off ?
    By peadar in forum Diesel Engine related
    Last Post: 27th October 2008, 23:01
  5. Map gone blank
    By Paul_O in forum Electrical & ICE (including SatNav)
    Last Post: 19th October 2007, 15:42
