Thread: Fuel Level.
    Jul 2009
    Australia
    Default Fuel Level.
    I have a 2003 Veccy, badged as a CDXI here in australia (3.2 V6). everytime i fill up from empty, it only takes 50L to fill, even though the manual clearly says its a 60L tank. i assume this is some sort of an inaccuracy in the fuel level meter? does anybody else have a similar issue?
    How do you know its empty? If your going by the computer then it will normally allow a safety buffer so you don't run out.
    Nov 2007
    North Wingfield, Chesterfield, Derbyshire
    Vehicle : Vectra C Hatchback Facelift
    Trim : Club
    Engine : Z18XE
    Mileage : 100085
    I've run the tank low on our facelift 55 reg Vectra C Club Z18XE (Petrol engine) until the low fuel warning light illuminated continuously then started to flash....tried it twice at different times - to satisfy my curiosity.
    Each time it needed 55.5 litres to top-up the tank until the delivery pump fuel nozzle cut-off valve operated...Conclusion....about 5.5 litres of fuel still left in the tank which has a capacity of 61 litres.....
    11 Post(s)
    Quote Originally Posted by Tony W View Post
    I can get approx another £1.50 to £2 worth of fuel in after the first cut off.
    Jul 2009
    Australia
    yeh i thought it would be as such, just wanted to see if everyones had a simmilar buffer
  1. Fuel level warning light......
    By Nik in forum Electrical & ICE (including SatNav)
    Last Post: 20th July 2011, 00:44
  2. Tuning box and fuel level beware!
    By djr69uk in forum Vectra C / Signum Car Chat
    Last Post: 29th June 2010, 23:30
  3. Fuel pressure sensor/fuel pump failure list following Watchdog investigation.
    By happychappy in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2009, 13:18
  4. oil level........
    By david.aka.judas in forum Vectra C / Signum Car Chat
    Last Post: 16th August 2008, 21:27
  5. Fuel level guage
    By Ian T in forum Electrical & ICE (including SatNav)
    Last Post: 16th March 2006, 12:43
