Results 1 to 10 of 14
Thread: FAO Keithy! (new griffin on grille)
    Liverpool
    Default FAO Keithy! (new griffin on grille)
    pics as promised
    new style griffin on grill, wheels and steering wheel
    going to finish steering wheel off with some chrome beading for edges when i can
    comments welcome
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    spot on mate. mine arrived on sat. can't wait to fit it.
    Lovin the one on the steering wheel. Where did you get that one?
    Sep 2009
    Glasgow
    looks good, bet it wasn't easy to replace steering wheel badge.
    Liverpool
    Quote Originally Posted by Keithy View Post
    ebay, managed to get a 46mm one from ebay, i made a few marks getting it off, so want to tidy it up with some chrome beading
    Quote Originally Posted by nokiaman1978 View Post
    2 hours! 3 finger nails and about 100 times the horn went off, so not really haha
    Jan 2008
    Dundee
    So did you just cut a dvd box shape it then glue it?
    Liverpool
    yeah, well traced outline, cut out and made sure it matched up, then sprayed black, then glued badge to backing, then once that was set hard, i used some tiger seal to put whole thing on grille.
    just taped it up then as if there was no pressure on it, it wouldnt have set in right position
    Jan 2008
    Dundee
    So the backing is actually fitted to the front of the V?
    Regular Member paul.sessions's Avatar
    leighton buzzard
    when i done my steering wheel irmscher badge, i unplugged battery so horn didnt go off.. and used a fine blade screwdriver only took a couple of mins. the irmscher one didnt fit properly either so i milled out the middle of the old badge and mounted the irmscher on inthe middle so the chrome ring was around the outside and hey presto...
    Liverpool
    some to the actual v, and some to the small plate in centre
    Jan 2008
    Dundee
    sorry for sounding silly but i'm really confused now.
    I'm sure it will become clear when i do it
  1. Replies: 2
    Last Post: 21st August 2011, 11:38
  2. Newbie Keithy from Dundee
    By Keithy in forum Introduce yourself.
    Last Post: 4th February 2008, 23:18
