Thread: Help with tuning box, please
    Oct 2009
    S Wales
    Default Help with tuning box, please
    I have a DTUK CDR2. Until recently I have used it for around 10 months with no issues. When fitted my SPANNER light comes on. The engine then looses power. The engine is definately noisey with it on. I sent it back to DTUK and was assured that it was fitted to another Vectra and run for a few days with no issues, all working fine. When I recieved it back from DTUK the jumper pin had been moved to a different map setting. The power setting was the same, 1 setting below the middle.I tried it again on my car(120 Vectra CDTI), this time it was as though it was too powerful, the power came in very quickly at 2000rpm, again it was very noisey(harsh deisel knock).
    When accelerating ( not full throttle) the light came on again and the engine stopped.
    DTUK have told me it could be the EGR valve, or many other things.Where is the EGR fitted on the 120 deisel.
    Has anyone else had these types of issues, and any ideas what it could be. Engine has done around 48k and is well maintined.
    Thanks in advance
    stockport
    Arrow
    Quote Originally Posted by ianm59 View Post
    Thanks in advance
    Boxes work by fooling the ECU into injecting more fuel into the common rail which in turn feeds the injectors.IMO,I would start off at the lower setting and work your way up until the car starts to exhibit the symptoms you are now experiencing,which seem to be over fueling.FELIXX.
    Oct 2009
    S Wales
    Thanks for the reply. The box was working fine. It is set below the standard set up. May try it at its lowest setting and start from there.
    Regular Member DarylAAS's Avatar
    South Shields
    I tested the box on my vectra buddy... worked spot on.. so dont know whats happening with yours.. although would do the egr etc...
    bournemouth
    could be egr valve and on the 120 vecs its at the back passenger side of the engine and also when i had problems with my 120 signum the dpf was at fault and after fixing that i got another fault which was the dpf sensors which there is 2 of them and then after that my intercooler went faulty and with all those problems i had the same simptoms as u
    Oct 2009
    S Wales
    Probably wisest move is to leave it off and see what develops/breaks first.
    Liverpool
    try resetting ecu, and refitting building up, just incase it is over fueling
  1. TDI tuning - tuning box thoughts so far...
    By nichols120 in forum Diesel Engine related
    Last Post: 4th February 2012, 20:48
  2. tuning box or not to tuning box that is the question
    By dazzer t in forum Vectra C / Signum Car Chat
    Last Post: 15th October 2010, 21:47
  3. need help with tuning box
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 4th September 2010, 19:49
  4. Caterman/T-Tuning Tuning Box for 1.9CDTi 150 (Z19DTH)
    By CHRISRi in forum Parts for sale
    Last Post: 25th May 2009, 18:49
  5. Diesel Tuning UK Tuning Box FOR SALE CDti 150
    By sshooie in forum Parts for sale
    Last Post: 1st April 2008, 16:49
dtuk pin positions
z19dth dtuk site:www.vectra-c.com
