Results 1 to 10 of 14
Thread: how do i adjust my headlights??
    Regular Member bangty 1's Avatar
    Sep 2010
    in a box
    Default how do i adjust my headlights??
    hi all can anyone tell me how to adjust my headlights (drivers side seems to be pointing at the ground) thanx lads
    Mileage : 000
    Viewed from the top looking at the black casing there are two alen key looking holes I presume they are for the up/down and left/right adjustment. But to which one does what I am not sure.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    the one towards the middel is up/down. (6 mm allenkey is needed)
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Duncan listed a method somewhere, park facing wall, garage door etc, mark centre of beam on wall. Pull beam height adjuster and set to 2nd position, turn allen secrew adjuster (one of the yellow ones back of headlights) and reset them to marks. Then if anyones dazzled you can drop it a notch on the beam adjustment inside the car.
    Sep 2010
    in a box
    thanx lads get on that now
    Sep 2009
    Glasgow
    yep used duncans method, and raised them waht a diff, and passed mot as well.
    Regular Member Exclusive BV's Avatar
    West Midlands
    I would like to adjust mine too but I dont have a garage door or wall to use.
    Does the allen key adjustment increase in clicks or is it smooth
    Engine : 2.2 Direct
    smooth
    Sodding Typical on Sea
    Quote Originally Posted by Exclusive BV View Post
    There must be a wall or some other flat vertical surface near you even the real of a car will do
    Sep 2010
    in a box
    just done mine i parked close to my dads car and used that as a mark
  1. Handbrake? is it self adjust?
    By dave1419 in forum Vectra C / Signum Car Chat
    Last Post: 17th February 2013, 12:31
  2. facelift headlights dont adjust
    By hairy31 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd October 2012, 18:48
  3. Help please, how to adjust the headlights
    By PeterVV in forum Electrical & ICE (including SatNav)
    Last Post: 6th October 2010, 21:10
  4. Clock adjust
    By johnny1983 in forum Vectra C / Signum Car Chat
    Last Post: 28th October 2009, 18:12
  5. Is it possible to adjust Auto Headlights
    By tramman in forum Electrical & ICE (including SatNav)
    Last Post: 17th July 2009, 16:59
vectra c headlight adjustment
vectra headlight adjustment
vectra c headlight alignment
adjust vectra headlights
adjusting headlights on vectra
vauxhall insignia headlight adjustment
vectra c headlight adjustment motorhow to adjust vectra c headlightshow to adjust head light on opelvauxhall vectra headlight adjustmenthow to adjust headlights on a vauxhall vectravauxhall vectra c headlight adjustmentadjust headlights vectra chow to adjust headlights on vauxhall vectraadjust vectra c headlightsvectra c headlamp adjustmenthow do you adjust your headlights on a 2007 vauxhall vectravectra headlight adjuster screwshow to align headlights corsa cvectra 2003 headlight adjustsetting up headlight beam on vectra c facelift how to adjust headlight opelHeight to ventre of headligh on vectra c vectra c manual headlight adjustmentset vectra c headlight beam adjustment
