Thread: 1.9 cdti 150 no power
    glasgow
    Default 1.9 cdti 150 no power
    hey guys, need some help on this, car starts fine, put it into drive as normal, go to take off and there is no power till about 2500rpm(think when the boost comes in) then its off like a shot back to normal. then same again when i stop for anything. thought it was the egr valve and the boost sensor so cleaned both of them and took it for a long run to clean it out. but just happens again after i do this, any ideas as i am now bald with this problem.
    thanks guys
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Have you checked the vacuum pipes?
    Gazza4
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Quote Originally Posted by baz_cdti_sri_150 View Post
    thanks guys
    You could also try cleaning the throttle body, have you got any fault lights showing. look for any split pipes/hoses.
    glasgow
    no fault light coming on. will have a look for a split pipe just now. and look at the throttle body aswell.
    Regular Member mozzer99's Avatar
    bristol
    posted in error
    Regular Member kamar's Avatar
    bradford
    id say egr
  1. No power from 1.9 cdti 150
    By garetmcc79 in forum Engine & Drivetrain
    Last Post: 1st April 2012, 08:04
  2. little power 150 cdti
    By smokydiesel in forum Engine & Drivetrain
    Last Post: 26th May 2010, 19:13
  3. 150 cdti with no power
    By pauly in forum Vectra C / Signum Car Chat
    Last Post: 7th January 2009, 00:23
  4. 150 Cdti down on power??
    By shrekster in forum Engine & Drivetrain
    Last Post: 7th December 2008, 00:19
  5. V6 CDTi - How much power?
    By Craig Rogers in forum Vectra C / Signum Car Chat
    Last Post: 11th February 2008, 20:31
