Hi i have cleaned egrand boost senor ,is there any thing else i can do to keep it running smoothly.![]()
throttle body for sure
then MAF sensor
also keep your eye on the vacuum hoses, intercooler hoses,
make sure filters changed routinely ( oil / fuel / air ), do the airbox mod
probably if you have time - once a year remove and clean intercooler and inlet manifold
and i'd use a premium fuel - it does pay for itself
Thanks for that ,i forgot to say did the air mod yest and replaced all vacuum pipes with silicone ones .
Is there a how 2 for throttle body and maf sensor![]()
there is one for the cdti
i'd guess the theory is same
as for maf
make a bath for it then
just remove it and soak overnight in pure alocohol... no water or wire inside will rust
make sure the maf electrical contacts are kept out of the solution too
cheeers
