Thread: Windscreen help!!!!
    Jul 2009
    durham
    Default Windscreen help!!!!
    Got a57 plate vectra c and every time it rains the inside of the windscreen always mists up if I put the heater on it goes away but then 5 mins later it'd back, obviously there's s leak somewhere but how do u find out where it's coming from??? And what can I do to prevent this????
    Regular Member Turbomanrony's Avatar
    Sep 2010
    LEEDS
    Quote Originally Posted by GAV_SRI View Post
    are u sure its a leak, sounds normal to me unless ur heater matrix is broken.
    u can buy products to stop it from misting its a window cleaner, just clean it with washin up liquid and make sure u dry it propply.
    Jul 2009
    durham
    I will giv it ago, to be honest it's more like condensation, I am permintly cleaning it with a cloth
    Sep 2010
    LEEDS
    check the carpets for damp also under the dash see if its wet thats were the matrix is located,
    preston
    there are 2 water drains under the scutttle panel.
    try cleaning them
    if they were blocked, maybe your pollen filter will be wet.......
    regards
    Full Member Big Sig's Avatar
    Unlikely the heater matrix has gone as you will be able to smell coolant in the car and your coolant level will be dropping.
    PRESTON
    Vectra's are beggers for misting up, but as has been said, it's very likely the scuttle drains are blocked and the pollen filter is wet. Check and clear drains,(the drivers side one on mine was completely blocked) fit new pollen filter and clean inside of windscreen. I found if i clean the inside of glass regularly, it doesn't seem to mist quite so fast.
    Double check for wet carpets too.
  1. windscreen
    By scottyd in forum Vectra C / Signum Car Chat
    Last Post: 29th May 2009, 10:28
  2. Windscreen?
    By mspvxr in forum Vectra C / Signum Car Chat
    Last Post: 23rd February 2009, 22:17
  3. Windscreen
    By chief29 in forum Vectra C / Signum Car Chat
    Last Post: 23rd October 2008, 17:18
  4. windscreen help
    By kpf1grandprix in forum Electrical & ICE (including SatNav)
    Last Post: 6th April 2008, 19:18
