Results 1 to 10 of 15
Thread: Help safeguard message beig displayed
    Regular Member chuckleuk's Avatar
    Jul 2010
    Swadlincote
    Default Help safeguard message beig displayed
    when i start the engine up after the car being dead locked im getting a message on the sat nav screen saying safeguard check with a picture of a man and what looks like an ultra sonic sensor logo, i did change the interior light a couple of days ago but error only cum up last night could it be that the connecter from sensors has come loose, any help appreciated
    Regular Member paul wingnut's Avatar
    durham
    Vehicle : vectra sri 150
    Engine : 1900 cdti 150
    safeguard is alarm fault when you changed light did you use your sensors might be worth taking it back out to check connections safeguard will go after you set alarm and no fault is found.
    Jul 2010
    Swadlincote
    yea i used my sensors but had the put the socket into the new light's main harness suppue it could of come loose will have to check it later, many thanks paul
    Full Member spennny's Avatar
    Blantyre
    Or try the big 30 amp fuse in the boot in the cubby to the left hasnt blown
    Jul 2010
    Swadlincote
    i'll have a nose at that aswell cheers guys appreciate the help
    Ely, Cambridgeshire
    60 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Had EXACTLY the same problem today, took the sensors out to fit a microphone for my car kit into the vent part of that panel. When I put it all back, got the "Check Safeguard" error and nothing I could do would get rid of it. Stripped the entire thing down and continuity checked everything, double and triple checked every connection and could find nothing wrong with it.
    Last resort I thought I'd force a reset of the system, disconnected the battery for half an hour and presto, no more error
    Jul 2010
    Swadlincote
    might have to give that ago then if noting else cures it, it funny tho coz it does happen everytime
    Full Member Robsey's Avatar
    North East Cheshire
    20 Post(s)
    Trim : Energy
    Mileage : 131,000
    By far the most common cause is the wires becoming disconnected near the rear view mirror / interior light unit, but a full reset (pulling the fuse in the rear fuse box) will do no harm.
    Jul 2010
    Swadlincote
    just had a look at fuse box and the really big fuse is 40amp is that the one for the alarm sensor
    Regular Member v6vc's Avatar
    Jul 2009
    Planet Earth
    Vehicle : Vectra & Signum
    Trim : GSi & Design
    Engine : 3.2 V6 & 2.8 V6 T
    Year : 02/07
    I had the this error come up once which seemed to be because the sensors stopped working. (No apparent reason why!).
    Disconnected the battery for a few minutes and there you go, sensors back working and message gone.
  1. check safeguard message fault, and computer screen staying on, what can it be?
    By taffy bhoy in forum Electrical & ICE (including SatNav)
    Last Post: 4th October 2012, 17:44
  2. Safeguard message and no alarm
    By MORGIE8153 in forum Electrical & ICE (including SatNav)
    Last Post: 26th July 2011, 21:44
  3. the check safeguard message
    By dansri in forum Electrical & ICE (including SatNav)
    Last Post: 24th January 2011, 19:15
  4. Safeguard Message
    By TJC77 in forum Electrical & ICE (including SatNav)
    Last Post: 15th January 2011, 21:28
  5. check safeguard displayed
    By denzilbud in forum Vectra C / Signum Car Chat
    Last Post: 11th June 2009, 00:42
how to reset safeguard vauxhall vectra
vectra safeguard reset
how do I clear safeguard from vauxhall vectra
