Thread: can anyone help
    Regular Member denzilbud's Avatar
    cambridge
    Default can anyone help
    after a drive out last nite the emissions light came on would the lambdas be the problemalso as long as the lights not flashing is it still ok to drive it
    Mileage : 000
    Best get the codes read if you can. I don,t know if it will do any harm to drive it though.
    Nov 2009
    Norfolk
    Should be ok to drive, but will need to get the fault codes out of it.
    Most likely to be a lambda sensor.
    Car may feel low on power or judder until its sorted.
    cambridge
    car seems to be running fine,i had a problem with a cross threaded lambda a little while ago and when it was replaced it didnt tighten properly so when i had the car serviced last month i got the bloke to re thread the down pipe and when i picked the car up he said that the lambda might need replacing and if the light comes on to give him a call
    Mileage : 000
    Might be worth giving that Guy a ring then, it sounds like he might have been waiting for "this" to happen.
