Results 1 to 3 of 3
Thread: intercooler pipe
    leeds
    Default intercooler pipe
    hi all ive fitted my fmic yesterday and it was a universal with ally pipes and on one of the pipes i needed to fit it has a branch little tube branching out of its and open so boost escapes from it. ive fitted that tube between the turbo and intercooler,so in theory cud i fit a boost gauge there or is it just best to change the pipe otherwise ill have to cap it off today.
    cheers
    Sodding Typical on Sea
    If this is on the pressurised side then yes you could get an adapter I suppose typically though the boost reading comes right up at the manifold IIRC
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    My boost gauge is tapped off on my intercooler to manifold pipe so yes you can
    You won't get a 100% accurate reading unless from the inlet manifol as del says but it's not far off
  1. Should these fit over my intercooler pipe?
    By Alank in forum Vectra C / Signum Car Chat
    Last Post: 2nd June 2011, 18:00
  2. is this an intercooler pipe?
    By richje100 in forum Engine & Drivetrain
    Last Post: 25th February 2011, 06:11
  3. intercooler pipe
    By sarahds in forum Engine & Drivetrain
    Last Post: 5th October 2009, 14:07
  4. Intercooler Pipe, HELP!
    By joewin1975 in forum Engine & Drivetrain
    Last Post: 22nd October 2008, 21:02
