Thread: Af40 auto gearbox loss of drive.
    Kent
    Trim : SRI
    Engine : 1.9 CDTI 150
    Default Af40 auto gearbox loss of drive.
    any one able to help
    got a 1.9 cdti 05 plate vectra with af40 auto gearbox problem when cold will drive for about 1/2 mile but thats it then you loss all drive as if the clutch is slipping.
    any one come across this problem able to give us a clue as to what the problem will be.
    cant find the oil dip stick on the suto box, is there a way to check the level? if so how?
    Regular Member Aikon58's Avatar
    Englandshire
    Vehicle : shatch- sports hatch
    Trim : cheap plastics
    Engine : metal
    Year : 1901
    Mileage : 999
    Don't like the sound of that,2k for a recon auto box at dealers
    to check the fluid level to make sure the box is full up,you need to take out the little torx screw on the bottom of the gearbox,and if fluid starts coming out,your box should be fairly full up,there is a sequence to do it,but i'm not 100% sure how to do it.
    Kent
    Trim : SRI
    heers aikon58.
    any one able to confirm how to check the level ?
    Kent
    Trim : SRI
    anyone?
    Hi Ricky. Its quite a complicated job getting the level right on the AF40 transmission and it would be better if you could beg borrow or steal a Haynes manual and read all about it .
    (Page 7b3)
    The oil level is indicator is part of the drain plug
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    As a rough guide I believe the level checking is close to :
    Vehicle on level surface (with access to drain plug)
    Car running and up to normal temperature
    Foot on brake and keep it there, handbrake on, select each transmission position for a couple of secs each.... P to 1 then back to P
    Car at idle (securely chocked and safety person to hand where possible, remove drain plug... fluid should be at the lower edge of the drain plug hole.
    Fluid should also be lovely rich pink colour .... if not enough fluid or dirty/dark in colour, consider a filter and fluid change.
    Although I have heard talk on later auto transmissions of a check plug as part of the drain plug.
    Kent
    Trim : SRI
    cheers mate yep your right its part of the drain plug
  1. Af40 Gearbox Limp Mode ( again )
    By viper8 in forum Engine & Drivetrain
    Last Post: 9th September 2012, 00:41
  2. Dexron III for my AF40 automatic gearbox?
    By Estate in forum Engine & Drivetrain
    Last Post: 30th June 2012, 10:22
  3. Need an AF40 gearbox!
    By the_rocker in forum Vectra C / Signum Car Chat
    Last Post: 30th April 2012, 17:47
  4. Correcet oil for AF40 auto box
    By Dougb in forum Engine & Drivetrain
    Last Post: 2nd July 2010, 14:17
af40 gearbox problems
gear box vectra c af40
vectra af40 auto box does not want to select drive when cold
signum auto loses drive when hot
is the vectra AF40 box reliable after engine remap
opel vectra c af40
vauxhall af40 transmission problems
drain transmission automatic fluid AF40
vectra auto loss of drive
how to fix af40 gearbox overheat
insignia automatic gearbox lost drive
