Thread: a few faults need some advice please
    Aug 2010
    herts
    confused a few faults need some advice please
    right ive just got a vec c 2.0 t sxi 46,000 on a 53 plate and got a few problems with it,
    9-3 wheel play slight knock
    lumpy start up sounds like something is loose and vibrating
    squeaking noise down near the aux belt when started up
    when pulling away from a roundabout in 2ND gear at low rpm engine rattles and vibrates as if it was going to stall.
    front end quite hard a bangs when going over a rough road surface.
    any help or advice would be great thanks.lee
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Get under the front end and check all the bushes and bearings ... clunking when driving over a lousy surface certainly sounds like there might be some worn out rubbers under there.
    Bad when pulling away in 2nd ..... then pull away in 1st
    9-3 wheel play .... which wheel ... steering ? front's ? rears ? some ? all ? just one ? which one ?
    Squealing aux belt ... check condition of the belt and pulleys (as best you can).... good chance the belt is on it's last legs.
    Lumpy after starting .... what state is your engine oil in ? Turbos need oil in decent condition. Consider something like ZX-1 to protect the engine/bearings while the oil's starting to circulate.
    Aug 2010
    herts
    9-3 wheel play drivers side front!
    Bad when pulling away in 2ND when its just come from 3rd like when you slow down then hit the gas again.
    oil is clear as its just been serviced, it sounds lumpy starting it up not when its running as it runs fine with all the power there. cheers.
    Aug 2010
    herts
    anyone else had any of this.
    Aug 2010
    herts
    is there anyone close to hatfield,herts that knows there way around these cars and would take a quick look for us.
    Aug 2010
    herts
    Aug 2010
    herts
    any more help please also think my alternator is making a squealing noise sound like something needs oiling, thanks.
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    Being a 53 plate, they also had a problem with the Aux belt pulley wheel breaking.
    The very bottom one from looking down into the engine. If on there way out they do make strange noises and cause rough tick over.
    Do a search on here, there is loads about it.
    I know been there done that repair.
    Could find the info on the top thread of this page 2.2dti owners.
    Aug 2010
    herts
    ok cheers, what abouut the 9-3 play in my front wheels.
  1. My new car faults!
    By ScottyV6 in forum Engine & Drivetrain
    Last Post: 26th September 2012, 22:09
  2. OP-COM faults
    By WoodleySaint in forum Vectra C / Signum Troubleshooting
    Last Post: 1st June 2012, 16:36
  3. faults
    By steelee in forum Tuning
    Last Post: 23rd November 2011, 00:46
  4. Vauxhall Customer Service Advice/letter (CDTI SRI Common FAULTS) Please Read
    By Warrenmole in forum Vectra C / Signum Car Chat
    Last Post: 7th September 2008, 10:29
  5. Have some faults so need a code reader! and advice!!
    By m0cea in forum Electrical & ICE (including SatNav)
    Last Post: 18th August 2008, 07:39
