Thread: Deep/quiet knock on low speed acceleration
    Regular Member Craig1985's Avatar
    harwich essex
    Default Deep/quiet knock on low speed acceleration
    I'm getting a deep but quietish knock from NSF when I pull away slowly and decelerate.( like a rubber hammer hitting under engine bay) Doesn't sound nothing like the clicking a cv joint makes. Also sure it's not engine mounts. Spoke to vx tech I see in town ( poor guy cant hide from me) and says drive shaft nuts can work loose and cause a knock. Any other ideas? Having a mate change top mount bearings sunday. As they make a noise once on a long drive.
    Regular Member david.aka.judas's Avatar
    Suffolk
    try the radiator mounts - spray them with grease/ oil and see if it improves.
    harwich essex
    99% sure it's not them, def off NSF suspension some where?
    preston
    have you changed your wheel on that side recently??
    harwich essex
    Done it with my old 19s and my new 17s?
    harwich essex
    Well after a couple of hours Sunday I think I have found the problem. When I went to undo the NSF suspension bolt il(in top mount) I found it was so loose I could have undone it with my fingers ! Been wondering if they accidentally left it loose when I got my 4wheel alignment done last year. ( also same sort of time I got tha knocking
  1. Help Needed Please...Knock knock...
    By wishy1976 in forum Suspension, Wheels & Brakes
    Last Post: 23rd March 2012, 00:34
  2. driveshaft/cv joint knock on acceleration or changing gear?
    By RyanNI in forum Engine & Drivetrain
    Last Post: 1st March 2012, 04:23
  3. Knock, Knock, Knocking...
    By Carmaduk in forum Suspension, Wheels & Brakes
    Last Post: 25th May 2011, 22:20
  4. Knock Knock whos' there
    By lizard in forum Suspension, Wheels & Brakes
    Last Post: 8th November 2009, 21:18
  5. Knock Knock Knockin on heavens door
    By lizard in forum Engine & Drivetrain
    Last Post: 17th January 2009, 00:10
vectra c knock when changing gear
