Results 1 to 10 of 11
Thread: How do I replace my coolant/antifreeze myself?
    Dunstable
    Default How do I replace my coolant/antifreeze myself?
    Basically with the winter coming up, I was thinking of changing the coolant/antifreeze as I don't know when it was last done and like to know it's okay. Is this something I can do myself, and if so how do I do it? I'm more electrically minded so haven't the best idea of where to start on this. Any tips on how to do it would be great, or should I just get the garage to do it when I take it for a service? Thanks in advance
    Have you checked the gravity?
    I asked my dealership what the renewal interval was and it's not listed!
    On my previous cars it was typically between 5 and 10 years
    However, in most cases the radiator had rotten through before that interval!
    Therefore the coolant was replaced then instead
    Sep 2010
    Glasgow
    Pretty easy to change. There is a drain **** at the near the bottom of the radiator. If you do change it you may want to swap the Thermostat as well if your car seems to be running at less than 85 degrees - if you have a 1.9 CDTI that is
    Full Member Big Sig's Avatar
    Or just take the bottom hose off the rad and the cap off the expansion bottle.
    Sep 2010
    Glasgow
    Parking slightly up the hill will most likely help you to prevent air bubbles in the heat matrix...
    Dunstable
    Nice one, thanks. After reading various other threads on this, I think I'll leave it. It's not causing any problems and the car is running great so why try to fix what's not broken. Thanks for the advice anyway
    Regular Member Craig1985's Avatar
    harwich essex
    Just make sure you have the right mixture as it stops corrosion in the rad and around the head
    Dunstable
    Well I've only ever topped it up using genuine gm red coolant. Car never overheats or runs cold. Was fine last winter, so guessing it's ok.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Good man!, stick with what you know!, the GM orange anti is strong, and there now 'only just' putting the mix/strength info on there bottles, so you can know for sure what ur mixing. as for corrosion i think you'll find the rads ali so its not so much a problem.
    Dunstable
    Nice one, thanks! Will stick to fiddling round with wires and high voltages instead
  1. antifreeze
    By matts1185 in forum Engine & Drivetrain
    Last Post: 29th November 2012, 14:02
  2. Antifreeze
    By stevie1 in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2012, 17:16
  3. Antifreeze
    By tomo610 in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2012, 23:21
  4. replace coolant tank.
    By frasedeb in forum Vectra C / Signum Car Chat
    Last Post: 2nd January 2011, 11:03
  5. If stuck, could you use washer fluid to replace coolant?
    By PeterVV in forum Vectra C / Signum Car Chat
    Last Post: 23rd October 2009, 16:31
vectra replace coolant vectra c
