Thread: plz help,P0340 Camshaft Position Sensor Circuit Malfunction
    Regular Member bedo13's Avatar
    Oct 2009
    EgypT
    Default plz help,P0340 Camshaft Position Sensor Circuit Malfunction
    hi guys,,
    I got this error in my veccy 1.6!
    Wat should i do؟؟
    Plz help
    Mileage : 000
    Might need to replace the Camshaft sensor. I had to replace one on our old Vectra B.
    Oct 2009
    EgypT
    Quote Originally Posted by ed taylor View Post
    Thnx alot,
    But no other solutions as this is very expensive here?!
    Wat will happen if i leave it?
    Mileage : 000
    The car. might not start, or even worse stop, as it might not be sure as to the camshaft and crankshaft timeing being correct, so as a failsafe it will stop the engine. It is best to get it done. how dear are they over there.Where abouts are you.
    Regular Member Dazzy2006's Avatar
    Notts
    U could try here - £44 + postage
    http://www.auto-essentials.co.uk/eco...01-p-2590.html
  1. Camshaft Sensor Error (P0340)
    By Kaput in forum Engine & Drivetrain
    Last Post: 16th February 2013, 16:53
  2. Y22dth po340 camshaft position sensor malfunction
    By GHz in forum Engine & Drivetrain
    Last Post: 5th January 2013, 21:06
  3. Replies: 2
    Last Post: 24th June 2012, 02:11
  4. P0340-28 Camshaft pos sensor circuit range/performance???
    By bafoo in forum Engine & Drivetrain
    Last Post: 13th September 2010, 07:28
  5. O2 Sensor Circuit Malfunction
    By marcdale in forum Electrical & ICE (including SatNav)
    Last Post: 31st May 2009, 21:21
vectra 3.2v6 starting problems crank position sensor
replace camshaft sensor vectra b
vauxhall 3.2 v6 cam sensor change
p0340 camshaft position sensor circuit malfunction vauxhall
vauxhall zafira camshaft sensor circuit malfunction
vectra 3.2 how many cam sensor
omega 3.2 v6 cam sensor location
