Thread: Can you measure your auto light switch?
    Regular Member yysnet's Avatar
    Jul 2010
    Scotland
    Default Can you measure your auto light switch?
    Can somebody with vectra auto headlight switch measure the resistant between PIN2 and PIN11, and between PIN5 and PIN11, while in "0" position?
    Thanks very much
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    I would if I knew how lol
    Jul 2010
    Scotland
    Quote Originally Posted by lofty View Post
    Thanks, just measure the resistor using a multimeter.
    To take out the switch, put it to position "0", then press the big headlight switch down(a bit hard), while pressing the button, turn it to "1", the button should now stuck "in". just pull the button and the whole switch box will go out.
    Pinout as picture:
    Attachment 35462
    @home
    Engine : 1.9 CDTi
    Getting the switch out is the easy bit... It's using the multimeter that I'm not familiar with, I've only ever used it to check continuity
    Regular Member scottyd's Avatar
    paisley
    just set it to ohms and do it
    @home
    Engine : 1.9 CDTi
    Cheers, will try and get it done for you tomorrow
    Admin plasma's Avatar
    On the Forum
    321 Post(s)
    Engine : 150
    Mileage : 74000
    Between pin 2 and pin 11 = 1.8k
    between pin 5 and pin 11 = 1.8k
    all with switch in 0 position
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Jul 2010
    Scotland
    Quote Originally Posted by plasma View Post
    This is the value in my non-auto switch, also is what i expected in auto.
    I am trying to modify the switch to enable auto headlight, but when mod it to auto, it always switch on the headlight, regardless the command from REC.
    The day/night from rec can be monitored by tech2 or vauxcom. It's correct in my car, i.e. output day when in bright and output night when in dark (or cover the sensor).
    So i think it's the BDM needs programming to activate auto headlight.
    BTW, All REC seems compatible with both type of sensor.
    Jul 2010
    Scotland
    Thanks lofty, expecting your result.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Quote Originally Posted by yysnet View Post
    Sounds interesting.. now plasma has to check the BCM with tech2 to look for options for autolights in other places .
  1. auto headlight switch AND daytime running light
    By nipmads in forum Electrical & ICE (including SatNav)
    Last Post: 28th September 2012, 08:18
  2. Need help activating auto light switch
    By john norris in forum Electrical & ICE (including SatNav)
    Last Post: 4th September 2012, 20:53
  3. Auto light switch
    By montyfert in forum Electrical & ICE (including SatNav)
    Last Post: 22nd January 2012, 21:28
  4. Auto light switch
    By sb1uk in forum Electrical & ICE (including SatNav)
    Last Post: 21st September 2011, 20:45
