Results 1 to 3 of 3
Thread: cdti Fuel filter drain
    Sodding Typical on Sea
    Default cdti Fuel filter drain
    Can anyone tell me how to use that drain cap under the diesel filter I cannot fathom how to operate it.
    Engine : 1.9 CDTi
    Turn it (Undo it) till it leaks out
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Yip - unscrew and it will drain the diesel from the filter housing..
    Easier to remove the housing and do is.. If you are draining to renew the filter, do not undo the top in situ as it will (potentially) split the plastic mold.
    Take it out and do it in a vice / workmate etc
    A
  1. How to drain fuel filter housing?
    By NoFinPhish in forum Y & Z30DT Specific
    Last Post: 29th November 2012, 20:31
  2. CDTi Fuel Filter
    By Homer in forum Engine & Drivetrain
    Last Post: 17th November 2012, 23:15
  3. Drain Fuel Filter 1.9 Cdti 120 2006
    By peepsie2 in forum Engine & Drivetrain
    Last Post: 24th July 2012, 20:49
  4. cdti 150 diesel oil filter drain stub
    By veralum in forum Engine & Drivetrain
    Last Post: 12th April 2010, 16:38
  5. How do you drain the diesel fuel filter of water
    By chrisvectra in forum Vectra C / Signum Car Chat
    Last Post: 26th November 2008, 11:04
vectra c 1.9 cdti water in the fuel filter
opel vectra c 1.9 cdti diesel filter drain
diesel fuel filter drain vauxhall vectra 120
water in diesel filter 1.9 cdti
vectra filter drain
vectra cdti water in fuel filter
zafira 1.9cdti how remove water from fuel filter
zafira 1.9cdti water in fuel filter
vauxhall zafira 1.9 cdti fuel filter drain
vauxhall signum 1.9cdti fuel filter water drainage
how do i drain the fuel filter on a vauxhall vectra 1.9cdti
vauxhall vectra 1.9 cdti how to drain water out of diesel filter
