Thanks Thanks:  1
Likes Likes:  1
Results 1 to 10 of 22
Thread: help...indicator bulb change on facelift vectra...
    Regular Member mark-sri's Avatar
    Oct 2010
    neston
    Default help...indicator bulb change on facelift vectra...
    hi every1 i seen this problem on a previous post but have come across this problem yday, i need to change the left indicator bulb(battery side) but find it reli hard to get at it, heard of 2 ways
    *remove front bumper to gain access
    *unbolt screen wash bottle to get acces to it(but spoke to a m8 who works at vauxhall and he said the funnel to the screenwash bottle is push fit so just pull it n shuld b able to get to the bulb)
    i still havnt been able to do it... :-(
    point of this post is just to see if any1 has any other tips or advice, or had the same problem...
    preston
    hiya
    on n/s the washer bottle filler is snap fit. but if you look at the top there is a small push clip holding it to the front of the car. unclip this then twist - pull the filler and out she comes........
    on o/s i just take the air box out. 5 mins and its done. whilst you're there you could do the air box mod and change your air filter.
    save time and money.....
    no need to undo bumper unless you fancy doing something to a/c , intercooler or radiator
    Oct 2010
    neston
    thanks ill av a look at it in a sec thanks, but wat i did notice yday was the main beam and side light were slight twist and the cap comes of to gain access to them bulbs but to gain access to the indicator n/s there was no cap to twist..just what looked like a little twisty knob ?(soz for the poor wording lol but hope u no what i mean)
    Regular Member dilan's Avatar
    Aug 2009
    dudley, west midlands
    hi mate, even taking out the washer bottle neck and removing the airbox you will still struggle to even get your fingers in to change indicator bulbs, i know this cos i changed mine to silver ones, in all honesty, for how easy it is ,i would recommend that you remove or at the very least loosen the front bumper..good luck
    Oct 2010
    neston
    thanks, just spoke to a machanic m8 ov mine n he said bring it up to his l8a , so presume he knows what he is doing(i hope) lol will keep u posted thanks for help lads
    Dunstable
    Iirc, the indicator housing goes slightly into the wing, so you cannot undo them or is very difficult to undo them with the headlights in. Ideally you need to take the bumper off and remove the headlight. You just twist the housing and the whole light holder comes out, easy to change once the headlight is removed....pain in the backside though just to change one bulb.
    Oct 2010
    neston
    brilliant thanks ....i no seems a ryt pain in the bum just to change a bulb.....hope this is the only downside to the car had it 2week an reli made up with it..
    * also the computer says the backbreak light o/s simble comes on now n again but bulbs working fine??
    Dunstable
    Quote Originally Posted by mark-sri View Post
    Could be the bulb is on it's way out. I've had this on mine, just comes up with the warning now and then. Usually after I've sat in traffic with the brake lights on. It's because as the bulbs get older, the filament inside it gets thinner and worn increasing it's resistance and throwing up a bulb error occasionally, change the bulb for a new one and it should be fine. Also, check the contacts in the bulb holder are clean as they can sometimes get a bit mucky and cause a bad connection to the bulb. At least the rear lights are easier to get to and you don't have to take half the car apart to get to them!
    Oct 2010
    neston
    ok yeh spot on tar i will check and change the bulb and yeh it dus come on mainly when i stop at lights or junctions...thanks for ur help
    Oct 2010
    neston
    also i no its of subject but is it easy to get a sig like urs apose to mine?, because i was on a cruise site a while back and a member done the sigs for ppl how did u go about getting urs? -(ademusic)
  1. Facelift Front Indicator Bulb
    By hothatch in forum Vectra C / Signum Car Chat
    Last Post: 3rd October 2012, 12:28
  2. vectra facelift indicator bulb
    By matt450 in forum Electrical & ICE (including SatNav)
    Last Post: 20th January 2011, 21:40
  3. Facelift SRI Driver's Side Indicator Bulb
    By DanR in forum Electrical & ICE (including SatNav)
    Last Post: 7th April 2010, 14:52
  4. How do I change Facelift Front Indicator Bulbs
    By ANDY W in forum Electrical & ICE (including SatNav)
    Last Post: 23rd April 2009, 23:48
  5. how hard to change indicator bulb
    By PeteRs in forum Vectra C / Signum Car Chat
    Last Post: 8th April 2008, 16:42
how to change indicator bulb on vauxhall vectra
vectra c indicator bulb
how to change a front indicator bulb on a vauxhall vectra
vectra indicator bulb change
how to change indicator bulb on vectra c
vectra front indicator bulb replacement
https:www.vectra-c.comforumshowthread.php119389-help-indicator-bulb-change-on-facelift-vectra
how to change front indicator bulb on vectra
vauxhall vectra front indicator bulb replacement
vectra c front indicator bulb change
change indicator bulb vauxhall vectra
vectra c indicator bulb change
how to change a near indecater bulb on a 2006 vauxhall vectra
vectra c indicator bulb removal
how to change indicator bulb vectra 2007
farside indicator bulb vectravectra c front indicatorhow to change vauxhall vectra indicator bulbhow to change vectra c indicator bulbvauxhall vectra indicator bulb replacementvectra c change indicator bulbhow to open the front left indicator vauxhall vectrachange indicator bulb vectra chow to change indicator bulb on vauxhall vectra life
