Thread: egr valve as anybody else heard of this
    Regular Member embo's Avatar
    stoke on trent
    Default egr valve as anybody else heard of this
    hi all was talking to a ex vauxhall mecanic about egr valves and why does te car has a flat spot between 1500 revs and 2000 revs ,he told me it was a problem with the egr valve and vauxhall did a quick fix untill they could find the answer , he explained they had drilled the ballbearing on the egr valve to keep it shut ,has anybody else heard of this ,,regards mick
    stockport
    Arrow
    Quote Originally Posted by embo View Post
    Look at some of the previous post on EGR problems and it will all be revealed.FELIXX.
    stoke on trent
    thanks for that ,but everytime i look at posts its always something different ,eg acelerater pedel etc etc ,just wondered if vauhall did the quick fix regards mick
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    If you have EGR problems read this!, This as always been my problem with the EGR, read ALL clean ALL but pay attention to the shaft / shroud i have pointed out, this sticking will eventually burn out the solenoid causing total failure, clean the EGR and this shroud/shaft at regular intervals & you should have a long life EGR I'm doing yr6/64k on the original.
    http://www.vectra-c.com/forum/showthread.php?t=105853
    Liverpool
    Egr valve faults are well documented on here, if you are having problems, you can get a blanking gasket from fiat to close egr valve. From what i have read, they tend not to like stop/start and short journeys
    stoke on trent
    yes thanks cleaned mine today ,ill give it a run tomorow regards embo
  1. Anyone heard of these???
    By PAULMAC77 in forum Electrical & ICE (including SatNav)
    Last Post: 24th December 2009, 20:51
  2. Replies: 17
    Last Post: 15th December 2009, 14:53
  3. Replies: 4
    Last Post: 31st January 2009, 01:54
  4. Have you heard this before.....
    By Big Davie in forum General Chat
    Last Post: 15th September 2006, 12:25
