Results 1 to 10 of 17
Thread: vivaro brake lights ?????
    Regular Member nigec's Avatar
    barnsley
    Default vivaro brake lights ?????
    Ive an 08 vivaro van and just noticed i have no brake lights working, any ideas ?? thought about fuses but dont know where they are. Any help would be appreciated. tnx.
    Regular Member vectraturbocal's Avatar
    Aug 2010
    leeds
    they are at the end of the dash at the passenger side, looks like a heater vent put it pulls off
    barnsley
    do you know which fuse it will be ?, and how do you tell if it is blown ?
    Aug 2010
    leeds
    im sure its a 10 amp (red) just pull fuse out mate and they are see through with either a straight bit of metal or an S shaped in the middle you will be able to see if its blown as it will be split and useualy look melted, there should be a key on the back off the cover with all numbered fuses and what they are for
    barnsley
    Nice one thanks, ill go investigate.
    Aug 2010
    leeds
    just post back on here i there are any more probz mate
    barnsley
    just checked fuses and there are all good, any more ideas mate ??
    Aug 2010
    leeds
    have you checked bulbs ok? if fuses are fine and bulbs are then you need to check for a live at your back lamps while someone presses footbrake if theres no live there then it could be either a broken wire or brake switch on pedal, do your rear sidelights work? on them they have stop and tail bulbs meaning your sidelights are your brake lights aswell but the brake filament in the bulb can go but the sidelight work fine, when you press footbrake have you got ignition on? just thinking off all possibilities as its hard when im not looking at the motor lol
    barnsley
    lol, yeah side lights are all ok, i try brake lights with engine running, i find it strange cus both brake lights are not working on side of van, and the brake light on top of door isnt working, so it would be to much of a coincidence for all 3 bulbs to pack in. Thing about is you dont know how long ive been with out them. Ive only had van 2 mts.
    Aug 2010
    leeds
    puzzled lol if i was there i could probz sort it im the van man at work lol but without seeing it im not sure, does sound like a brake switch, check the bulbs mate make sure they are all 12v if theres a 24v in there it would blow them mind you it would blow sidelights aswell but its worth a look,i have had a van in before that all 3 brake bulbs blew that was on a 59 plate, you will find them door ones always go the vivaro didnt put special strong bulbs in like the transit to avoid them popping when the rear doors are slammed shut.
  1. Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2013, 18:56
  2. Brake lights ( how many bulbs )
    By HITFACTORY1403 in forum Electrical & ICE (including SatNav)
    Last Post: 29th June 2011, 12:35
  3. Bulbs for brake lights?
    By mishima in forum Vectra C / Signum Troubleshooting
    Last Post: 12th May 2011, 15:06
  4. Hot Brake Lights
    By Guyver1 in forum Vectra C / Signum Car Chat
    Last Post: 3rd October 2008, 16:24
  5. rear brake lights
    By jofess in forum Electrical & ICE (including SatNav)
    Last Post: 12th October 2007, 23:42
how to change a brake light bulb on a vauxhall vivaro
how to change break light on nissan primastar 54
vauxhall vivaro brake light bulb
vauxhall vivaro brake light fuse location
vectra brake light fuse 08 plate
vauxhall vivaro brake lights not working
brake lights not working on vauxhall vivaro
how to change brake light bulb on vivaro
vivaro rear lights not workingvauxhall vivaro no brake lightsno brake light on Vauxhall Vivaro vanhow do I change a brake light bulb on a Vauxhall Vivarovauxhall vivaro rear lights not workingvivaro brake light switchfuse box on nissan primastar 59 platehow to change brake light on vauxhall vivarovauxhall vivaro break lightsstop light bulb on a vauxhall vivarovivaro brake light fusevauxhall vivaro brake lightsvhanging a bulb on taillight vivaro vanbrake light failier vauxhall vavero 2013vivaro loss of brakelightsvauxhall vovari keeps blowing rear light bilds
