Results 1 to 3 of 3
Thread: Noise over speed bumps
    Stockport
    Default Noise over speed bumps
    53 plate signum v6 cdti
    When i go over a large speed bump i get a grind`ish noise up it and down it.
    Could this be the drop links ??
    Car has had new springs recently
    Regular Member kentish_bloke's Avatar
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    i think many people have had this problem, myself included since fitting lowered springs. there seem to be many possible causes, such as radiator mounts, drop links, strut top bearing, spring sleeves and anti roll bar bushes.
    i have new drop links to fit & hope that they may help, as i dont fancy dismantling the front struts again to fit new top bearings & spring sleeves.
    start by getting some white grease on the radiator bottom mounts & the ARB bushes.
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    If your going to change drop links you might as well do the arb bushes at the same time . they only cost a few quid and your doing half the job allready when changing the links
    and still loving it
  1. Noise when driving over speed bumps
    By jake.clay in forum Suspension, Wheels & Brakes
    Last Post: 9th September 2011, 02:47
  2. Horrible noise when going over speed bumps
    By mikey362 in forum Suspension, Wheels & Brakes
    Last Post: 5th February 2011, 16:51
  3. knocking noise, over speed bumps ????
    By sthomson1 in forum Suspension, Wheels & Brakes
    Last Post: 18th January 2011, 21:14
  4. squelching noise over speed bumps?
    By bigben in forum Suspension, Wheels & Brakes
    Last Post: 27th November 2009, 10:54
  5. Noise over speed bumps
    By spatch in forum Suspension, Wheels & Brakes
    Last Post: 20th December 2008, 21:49
Speed Bumps
2005 vectra grinding going over bumps
