Thread: Oil Leak 2.2DTI Help Please...?
    Regular Member congaman's Avatar
    Sep 2010
    UK
    Default Oil Leak 2.2DTI Help Please...?
    I have just bought this car and noticed a wet oil leak.
    I don't know to much about engines but would like some advice from you guys.....please.....
    Here are the pics:
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Looks like the rocker cover esp from 3rd pic you can see the gasket all wet
    Irmscher Insignia CDTI 130
    Sep 2010
    UK
    Thanks for the fast response....what is a rocker cover and how bigger a job is it to fix and what is the cost.......?
    Sep 2010
    north east uk
    The rocker cover is the bit in your first pic that houses the yellow coloured plug where you top up the oil.
    Interested in this thread as my 04 reg 2.0 DTI that i got this week also has a leak around that area......my first suspect was the rocker cover gasket,but i have not as yet renewed the gasket. I have changed them on my previous car (Vectra B with X18XE engine), should be fairly easy to change on these engines if neccesary
    What i did do was to spray the oily areas with gunk, let it soak for a bit then hose it off. Have done around 50 miles since & havent seen any leaks so far.
    Possible that someone spilt oil when filling it & didnt wipe it all off?
    Sep 2010
    UK
    Anyone else with ideas about rocker cover replacement?
    Nottinghamshire
    Looking at the fact that there is oil on the black plastic engine cover in front of the oil filler cap and over most of the top of the engine around the oil filler cap, this might (if you are lucky) just be the result of an oil top-up that missed the hole and has not been properly cleaned up.
    Any oil that misses the oil filler hole tends to runs off towards the front of the engine and under the black cover because the oil filler hole sits in a recess except at the front where it sits flush - so this is where the oil runs off.
    Take the black plastic cover off the top of the engine and see if this is a possibility. Wipe away all of the oil that you can find then keep an eye on it to see if more appears in which case you may well have a leak. Also keep an eye on your oil level as this may get low if you do have a leak.
    Sep 2010
    UK
    I have cleaned the whole area with Carb cleaner. So I will spot any new oil that may leak out. I will keep watch over the next few weeks.
    I have been checking the oil levels everyday. They do not seem to change......
    Keep you all posted........if you wish......x
    Nottinghamshire
    Quote Originally Posted by congaman View Post
    It's the law . Also good information for anyone with a similar problem in future...
  1. Diesel Leak 2.2dti
    By Suffolk Boy in forum Vectra C / Signum Car Chat
    Last Post: 2nd December 2012, 22:19
  2. 2.2dti vacuum pump leak
    By Al 22 dti in forum Engine & Drivetrain
    Last Post: 3rd April 2011, 15:07
  3. 2.2DTI Coolant leak
    By Innes in forum Engine & Drivetrain
    Last Post: 14th March 2011, 21:17
  4. Leak, front end creak, refurb, bent locking wheel key and another leak =(
    By nick-v2.2 in forum Vectra C / Signum Troubleshooting
    Last Post: 15th February 2010, 19:58
  5. oil leak from injector tube 2.2dti
    By Beavis in forum Engine & Drivetrain
    Last Post: 11th April 2007, 08:00
https:www.vectra-c.comforumshowthread.php119330-Oil-Leak-2-2DTI-Help-Please
vectra c 2.2 dti oil leak
vectra c 2.2 dti turbo leaking
