Results 1 to 10 of 16
Thread: F40 gearbox oil plug, what size?
    Regular Member yysnet's Avatar
    Jul 2010
    Scotland
    Default F40 gearbox oil plug, what size?
    It's more and more difficult to engage 2nd and 3rd gear now, decided to change the oil as per how2.
    Went to stealer today and find 2 type of oil filler plug, M10x1.0 and M18x1.5, which is the one i need please?
    There is only one size of drain plug, M18x1.5
    PS: It surprised me that arnond clark do not have any sump plug, gearbox oil filler and drain plugs in stock within whole glasgow area....
    PSPS:Engine is 120ps, gearbox F40.
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    there are two plugs, a top (refill plug) and bottom one (drain plug). i bought them and then lost them so used my existing plugs.
    Regular Member Jezzy's Avatar
    S.E
    On mine, (2.0T F40) the drain plug and fill plug were the same part number.
    Jul 2010
    Scotland
    Quote Originally Posted by Caveman_nige View Post
    I would like to replace the top (filler) plug and drain plug as obama's (Jezzy's) how2.
    The top plug have 2 sizes.... I will order the one with same size as bottom plug.
    S.E
    Quote Originally Posted by yysnet View Post
    Yes do that, and worse case scenario is that you'll have to reuse the old fill plug if the new one doesn't fit; it's only the bottom one you shouldn't reuse as it doesn't have a washer on it.
    Oct 2009
    Luton
    11099092 M10 used to check the oil level
    55561146 M18 for filling
    11099271 M18 for draining - not sure but I think this may be magnitized too hence different PN's for filling & drain.
    S.E
    There's no oil check plug on the F40 - just a fill plug and drain plug.
    Oct 2009
    Luton
    Jezzy not quite....guess the EPC is wrong again!!!
    I did some digging on the mothership......
    Only early design F40 have the 11099092 M10 inspection / filling plugs.
    This plug was deleted some time in 2003 Model year, because a change in oil volume 3.0L to 1.8L / 2.2L.
    Could even be that Vectra / Signum wasn't effected by this change as the F40 was introduced for 03.75 MY.
    Regular Member PORKBALLS29's Avatar
    Epping
    Just been told by Stealer that part No 55561146 has been changed to 55568847 for anybody that needs it.
    Jul 2010
    Scotland
    Get the stuupid order placed,
    V0055568847, 6.15pound,
    V0011099271, 2.32pound
    yes 55561146 has been changed to 55568847
  1. vec c gearbox oil and plug
    By -stuuby- in forum Vectra C / Signum Car Chat
    Last Post: 25th September 2011, 01:43
  2. Spark plug wrench size
    By devore in forum Vectra C / Signum Car Chat
    Last Post: 28th February 2010, 23:19
  3. Oil plug size
    By jrh1 in forum Vectra C / Signum Car Chat
    Last Post: 23rd January 2010, 18:08
  4. Help please: - what size plug socket
    By PeterVV in forum General Chat
    Last Post: 24th February 2009, 20:41
  5. 1.8 sump plug T size
    By Ste in forum Vectra C / Signum Car Chat
    Last Post: 25th August 2005, 00:25
size of nut on gearbox vauxhall vectra
opel vectra gearbox oil measure length
vauxhall f40 gearbox drain plug size
f40 gearbox oil
what oil in f40 gear box
f40 gearbox drain plug part number
best oil for f40 gearbox www.vectra-c.com
how many gearbox oil f40
