Thread: Idea regarding EGR problems!
    Sep 2010
    Hartlepool
    Default Idea regarding EGR problems!
    Am not sure at all if this would work, but I'll never know if I don't post it. It may not work or it may be an ingenius idea lol.
    I have read on many a thread about egr valve "sticking". I take it that this is the plate inside not being freely able to move from closed to open position due to carbon deposit buildup?
    What IF the EGR valve was modified so the diameter of the moving plate was slightly reduced OR a groove was somehow profiled into the inside of the body (a groove around the inside diameter) where the plate sits at it's closed position, leaving a small gap for the carbon to move more freely and not get stuck as much?
    It's not something that I'm planning to do, just an idea that may just work.
    All comments appreciated.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    The key to the EGR valve doing its job is when its closed for it to be perfectly sealed. Anything that may affect this is not a good idea, and I can't picture your idea helping in this.
    Sep 2010
    Hartlepool
    confused
    Thanks for your comment. Was just a suggestion to maybe stop it sticking.
    What about inlaying the circular part of the egr body around where the valve closed position is with an alternative material that carbon could not stick to?
    Would this be possible? Maybe an anti-stick gasket material fixed in there?
    Full Member GazVXLINE170's Avatar
    Jun 2007
    Scotland
    Vehicle : Insignia
    Trim : SRI VX-Line Nav
    Engine : 2.0 CDTI [170 PS]
    Year : 2015
    Mileage : 27000
    As Dan says m8, it will only make the 'effects' of a malfunctioning EGR valve worse.
    When the EGR valve fails to operate - via a broken solenoid or very bad corrosion and the valve can not open, the engine will perform better as the pressure in the exhaust manifold is maiintained and clean air going into the combustion chamber.
    When a valve jams open (usually due to corrosion on the solenoid) or is slow to close then this will produce the Flat spot effect under 2,000rpm, and probably reduce power output above 2,000rpm where it should be closed.
    Gazza4
    Insignia VX-Line Nav CDTI 170.
    preston
    short of teflon coating it there's nothing to stop the stuff sticking other than reducing the oil mist and regular cleaning of the valve and solenoid
    shame though as we really need a better solution
    Lancashire
    Trim : XP NAV
    Quote Originally Posted by mparks8590 View Post
    ..shame though as we really need a better solution
    Blank it and remove from ECU
    Regular Member yysnet's Avatar
    Jul 2010
    Scotland
    How about place a particular filter before egr?
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    There's also one other point to remember ...
    ... acceptable normal performance for a reasonable time period = customer happy
    ... occasional failure of readily replaceable item = manufacturer/servicing agent happy
    If you can modify an assembly that occasionally fails to perform far longer between failures, good on you. But no way will GM/Vx/Op pick up on the same idea as that will reduce their income from parts, servicing and repair.
  1. crusie control problems, anyone had similar problems?
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 2nd October 2011, 21:20
  2. 1.9 cdti auto problems problems
    By trigger in forum Engine & Drivetrain
    Last Post: 28th September 2009, 17:20
  3. Good idea / Bad idea......?
    By david.aka.judas in forum Vectra C / Signum Car Chat
    Last Post: 3rd September 2009, 09:09
  4. superchip good idea or bad idea
    By lewrymyster in forum Vectra C / Signum Car Chat
    Last Post: 3rd July 2008, 19:14
  5. superchip good idea or bad idea
    Last Post: 26th June 2008, 19:09
