Thread: Smoking 2.2 direct , valve stem seals done but still smokes , what next?
    perthshire
    Default Smoking 2.2 direct , valve stem seals done but still smokes , what next?
    Hi everyone , i have a signum 2,2 direct petrol that has caused me a fair amount of grief but i still like the car , the car is burning oil profusley and the did the valve stem oil seals but unfortunately it is still drinking oil at a hell of a rate and they now want to do the piston rings , are they in the right direction? will it cure the oil burn? is there anything else that would cause it to go through so muchoil ? the car is a 2004 with 84 k and a full service history , it is using a litre per 100 miles and smokes like second world war destroyer , please help with advice etc , i have spent too much to change the engine so thats a last resort many thanks again A Mcfarlane
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    There is mention in Vx TIS of oil scraper ring failure in the 2.2 direct. In fact the none direct had the same problem and I got mine replaced under warranty.
    perthshire
    Thanks , i assume thats all it can be , at least they are on the right track , thanks much appreciated , i hope this cures it , A M
    perthshire
    I have now had the engine completely rebuilt including new chains,tensioners, valve stem oil seals ,scraper rings , hp fuel pump , coil pack, plugs,various other bits and bobs and cost around 2K and all that was the matter was the scraper rings - cost around £500 ,the other parts were used as the vauxhall technician tried to find the problem , i have now sold the car and have an alfa 147 2 litre manual , 29k and immaculate , belts done and car serviced 6 times in its 4 year life and it drives and looks new , never seen the dark side of 60 mph and i am the second owner , i will never have another vauxhall , my wifes 2 year old astra will be replaced with a focus , my sons 1 year old corsa will be replaced with a fiesta and my daughters 3 year old corsa will be a ford ka in a couple of months time , i e-mailed vauxhall and didnt get an answer , i have had vauxhalls for years ,never again , i really liked the signum, good luck everyone and thanks for your help , Alan Mcfarlane
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    Why all the cost one simple compression test would have told the story!!!
    perthshire
    I have no idea , i am a teacher -not a mechanic , the vauxhall so called mechanic started off by replacing the oil level sensor which meant he had to drop the sump , this obviously didnt cure the oil usage!! he then put the car on diagnostics as it was running rough and thats when he started to chase the problem at my expense , a sorry tale and an expensive one , why wont vauxhall admit there is an issue , why wont they offer some recompense ,why did the vauxhall dealership not help financially after they made so many mistakes , thanks vauxhall and arnold clark !!
  1. Valve stem seals. Do they go on the Vectra C CDTI
    By smiley-sri in forum Vectra C / Signum Car Chat
    Last Post: 26th May 2016, 06:27
  2. 2.2 direct fuel pump - seals?
    By seanturpin in forum Engine & Drivetrain
    Last Post: 3rd May 2012, 23:14
  3. valve stem seals
    By Madmarky01 in forum Vectra C / Signum Car Chat
    Last Post: 7th April 2012, 16:51
  4. Z22SE Valve Stem Oil Seals
    By a15nma in forum Engine & Drivetrain
    Last Post: 28th November 2011, 23:00
  5. Replies: 0
    Last Post: 30th September 2010, 19:11
astra 2.2 head reworked still smokes
how long to change valve stem seals on 2004 astra 2.2 petrol engine
vauxhall vectra 2008 valve stem seals
z22se stem seals
vectra c 2.2 direct smoking
vectra c 2.2 piston rings
2.2 petrol vauxhall zafira smoking
zafira 2.2 smokes
vectra stem seals
Vauxhall astra replaced my valve stem seals but car still smoking
vectra c 2.2 direct valve stem seals
vauxhall vectra c 2.2 direct burning oil
zafira 2.2 smokes when hot
piston rings vectra
