Results 1 to 10 of 16
Thread: HID installation - confused?????????
    Regular Member PeterVV's Avatar
    Oct 2007
    south wales
    Default HID installation - confused?????????
    OK just got my parcel from HID direct, opened the box, read instructions, and WTF? DRILL HOLE IN CENTRE REAR COVER OF LAMP HOUSING WITH A 25MM HOLE CUTTER??????????? ARGH! dont have one,
    and the wiring diagram????? whats the extra connectors for on the cluster????
    HELP!
    VIP-Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 Vtec
    Mileage : 64500
    I found the inside of a roll of insulating tape was 25mm so just drew a hole with a pencil and then cut it out with a stanley knife.
    The 2 spade connectors connect to the original socket that fitted to the original bulbs, then you just connect all the connectors together(they all only fit one way) the last one connects to the HID bulbs. Did you get cancellers with your kit?
    Sodding Typical on Sea
    It's as simple as he says mate, but be sure all the polarities are round the right way as the plugs can be connected to either side you need to make sure they all line up or the lamps won't light!
    Oct 2007
    south wales
    Yep, but the instructions dont mention the cancelloers!!! as if I wasnt confused enough already!
    Bristol
    If you got the Vauxhall kit from them then the cancellers are built into teh ballast's I believe.
    My package from the was attempted delivery yesterday but was at work. Collecting tomorrow for fitting at the weekend.
    The spade connectors go into the light wiring inside the housing
    Connect the power lead to the power lead
    Connect the rubber bulb fitting to one side of the cancellor, connect the cancellor to the Ballast.
    With me?
    Oct 2007
    south wales
    "8.Fix well salver by bandage. ( Note : installing ballast should be far from engine and place of temperature.
    9. Pressure wire of HID light should connect pressure wire of ballast. Make low pressure wire of ballast connects with 12v power wire of original car light. If added resistant, the low pressure wire of ballast should connect with resistant."
    Can anyone translate this?
    So the alarm cancellors are wired in line with the lights? ( more to mount somewhere )
    what are the two square-ish metal clips for? not mentioned in instructions or confusing diagram?
    which is + red or black?
    red is positive
    and yes the wire in line
    Regular Member Dazzy2006's Avatar
    Notts
    Quote Originally Posted by PeterVV View Post
    I think the bin is the best place for the manual
    Try without the cancellors 1st because mine wouldnt work at all with them but there perfect without them.
    The metal clips are to fix the hid bulb into the holder - but u only need to use them if your bulb is held in with a metal clip iirc
    Red is +
    Just plug the wire that comes from the ballast into the wiring that connected to the original bulb
    Take a look through the thread below because i was just as confused as you before i fitted them
    http://www.vectra-c.com/forum/showthread.php?t=116534
    Oct 2007
    south wales
    cant remember if it is held in with a clip or not, will check when I have a look.
    Shall I try without the cancellors first?
    Where did you fit the ballasts on yours?
  1. Following on from the ECC Installation
    By paulhb in forum Electrical & ICE (including SatNav)
    Last Post: 15th May 2012, 14:24
  2. HID installation help please.
    By SillyMoose in forum Electrical & ICE (including SatNav)
    Last Post: 15th January 2011, 20:54
  3. Double Din DVD Installation
    By Danwells72 in forum Electrical & ICE (including SatNav)
    Last Post: 9th November 2008, 18:10
  4. Avic installation
    By johnny kebab in forum Electrical & ICE (including SatNav)
    Last Post: 1st August 2007, 09:56
  5. ps2 installation.
    By Silver V in forum Vectra C / Signum Car Chat
    Last Post: 26th June 2007, 10:22
