Results 1 to 10 of 26
Thread: Top strut bearing help/advice
    Regular Member Craig1985's Avatar
    harwich essex
    Default Top strut bearing help/advice
    Every now and then I get a knocking/creaking/squeaking noise from the front of my car on long journeys with a full load. It makes a noises while stationary or moving when the steering wheel moves. I stuck my ear on the top mount and 95% sure it's that. Now question is, is it likely the bearing or housing? Think I've read somewhere that there's a rubber bush there also?
    Also are these main dealer parts only?
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    ECP sell them, think they are around £40 a pair, not a clue what they are from VX mate.
    harwich essex
    I phoned ecp and said they didn't do them? Have u had some from there? Was they just bearings or the whole housing/bearing
    West
    they're a closed unit roller bearing in a plastic housing, they do come apart & can be greased up if you're careful
    Regular Member Hyperhart's Avatar
    Jan 2010
    Luton, Bedfordshire
    Vehicle : Astra GTC VXR
    Trim : VXR
    Engine : 2.0t
    Bearings from Vauxhall are i think between £15-£20 + vat each, unless your down as a Vauxhall employee and then they drop to a tenner each as i got quoted on them yesterday.
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Quote Originally Posted by Craig1985 View Post
    http://www.eurocarparts.com/ecp/c/Va...fd4e67d2f&MTGK
    That is a different link than when Ive looked before, they were defiantly £40 a pair. Did you try your own reg number on the ECP site?
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Quote Originally Posted by Hyperhart View Post
    Just as well buying VX then at that price.
    Sodding Typical on Sea
    I had this same thing as you describe got mine done at the Vx dealer but ECP do not seem to list them, but good old ebay does
    http://cgi.ebay.co.uk/VAUXHALL-VECTR...7#ht_500wt_928
    harwich essex
    Quote Originally Posted by Derek Mc View Post
    Sounds expensive if they are 20+vat at vxl
    harwich essex
    Thanks das, just found them on ecp with my reg, I'll ring vxl to see what a oem price is. Did u have same symptoms as me?
  1. Advice required Wheel bearing IDS or not IDS Signum
    By Earlonics in forum Suspension, Wheels & Brakes
    Last Post: 8th October 2011, 13:04
  2. Strut top bearing changed but now pulls to right
    By winnie2457 in forum Suspension, Wheels & Brakes
    Last Post: 29th January 2011, 13:46
  3. Not another strut bearing thread...
    By parsco in forum Handling & Braking
    Last Post: 15th February 2010, 13:55
  4. strut bearing
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 5th November 2009, 09:50
  5. strut top bearing?
    Last Post: 10th September 2009, 19:55
