Results 1 to 10 of 17
Thread: 314mm caliper clips
    Jun 2009
    South Coast
    8 Post(s)
    Vehicle : Signum & Insignia
    Engine : POS derv
    Question 314mm caliper clips
    why do the spring clips that clip around the front of my 314mm calipers keep pinging off? What is the actual reason for them.?
    The spring clips that were on my old 302 calipers clipped into holes these seem to be crap, they are the correct ones..
    The clips hold the pads in place mate. If you look on the pads, there should be a small recess in the middle of the pad springs (the metal bit with 3 prongs on it). On the caliper spring itself, there should be a small angular bit which sits inside this recess, preventing the spring from coming off the caliper.
    Apologies for the Twin Audio thing BTW, my memory is rubbish... Do you still need the info mate...?
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    ok, will go and have another fiddle and see if i see what you mean, do you have any close up pics of your old 314mm calipers showing them on etc..?
    yeah mate, still need the pin info to finish the job...
    In this image, red bit is the caliper spring, yellow part is the back of the brake pad where it sits on the carrier, andf the pink bit is where the spring clips in to it...
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    it seems my outer pads fromthe saab bloke have had their clips broken of, i have one, was wondering what it was for. Seems i will need to get another set of pads and drive without the spring clips on for a few days.
    Mine went through it's MOT without one fitted when I couldn't get it to sit properly without taking the wheel off. If you have a spare pad it's only a ten minute job to remove the caliper and fit a new pad, but you'd really need to replace all 4 pads on the front at the same time to ensure even wear levels and equal braking...
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    way ahead of ya mate...
    Hanging Heaton
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    Anyone have the part number for these clips? Just lost passenger side ffs
    Regular Member Al 150 cdti's Avatar
    fareham hampshire
    Engine : 1.9cdti 150
    bumping a thread from almost 4 years ago lol
  1. Caliper spring clips
    By VeccyMike in forum Suspension, Wheels & Brakes
    Last Post: 24th August 2012, 10:40
  2. 314mm Brake Caliper code..?
    By dv8 in forum Suspension, Wheels & Brakes
    Last Post: 25th August 2008, 13:04
  3. Brake caliper spring wire clips
    By JonR in forum Vectra C / Signum Car Chat
    Last Post: 23rd February 2008, 07:21
vectra brake caliper clip
retain clips vectra c calliper
vauxhall vectra front brake caliper clip missing
