Results 1 to 2 of 2
Thread: Rear Brake Pads
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    Default Rear Brake Pads
    Is it only the ones with the butterfly spring that are available these days? Been having the rattling pad syndrome and went out and stretched the springs back as they were completely flat on both sides but by the time I got to the bottom of the street the rattling had started again, all be it not as badly. I remember that the original pads attached to the actual caliper.
    On a separate note I had noticed when I did the rear brakes the rear slides were quite stiff even though they were cleaned out and the brakes were slightly grabbing when I came to a stop. Well I decided to remove the rubber slides runners from the caliper and noticed heavy corrosion build up under the rubber. Some 180 grit sand paper soon took care of that and with the rubbers refitted the slides now move so much more freely. First time I have ever seen this.
    Devon
    The pads were modified - all pads now have the spring clip and not the one that attaches to the caliper. Re the rattling - replace them with genuine GM pads and you won't have a problem!
  1. Rear Brake Pads
    By tony-1977 in forum Vectra C / Signum Car Chat
    Last Post: 23rd February 2011, 18:25
  2. rear brake pads
    By gdansk in forum Vectra C / Signum Car Chat
    Last Post: 8th July 2010, 08:21
  3. Rear Brake Pads
    By steve-wolves in forum Suspension, Wheels & Brakes
    Last Post: 17th August 2009, 14:18
  4. Rear Brake Pads
    By cp123 in forum Suspension, Wheels & Brakes
    Last Post: 24th May 2009, 13:15
  5. Rear Brake Pads
    By CHRISSMART41 in forum Suspension, Wheels & Brakes
    Last Post: 16th October 2007, 18:22
vectra c rearbrake pads with springs
