Results 1 to 10 of 14
Thread: How to remove and replace hazard light switch?
    Northern ireland
    Default How to remove and replace hazard light switch?
    My hazard lights no longer work.
    I believe it is the switch on the dash that's failed.
    I have a 2002 vectra c.
    Have removed the switch cover but cannot get the switch itself out. Any ideas guys?
    Thanks.
    Full Member paul.sessions's Avatar
    leighton buzzard
    take the cover off and get a pair of pliers on one side of the little square shaped mount and pull hard.. should come out sometimes they will come off with the cover
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    my hazards have stopped working as well this week... did changing this switch fix it? has anybody else come across this? Is it an MOT failure?
    Full Member Niall83's Avatar
    Nov 2009
    Belfast
    never saw that radio before
    AirBox Mod-Angel Eye head lights-HID 5000k-Colour coded grill-GID to CID-Auto Dim rear view Mirror, Rear Parking Sensors, Signum Fog surrounds, 19" Audi A5 rep Alloys, Eibach 30mm Pro-kit Lowering Springs.
    Mileage : 000
    Quote Originally Posted by Niall83 View Post
    Me neither.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Its a borrowed picture i can see.. as its from a Holden Vectra (that radio is only for that marked)
    Jun 2009
    South Coast
    glad you sorted that out, any ideas on the hazard light issue though
    Engine : 2.2 Direct
    I should just pull out.. just like every other switch...
    Jun 2009
    South Coast
    but we do not know if simply changing the switch will resolve the failed hazard light issue? I will send a PM to the OP and see if he is still about....
    Full Member Big Sig's Avatar
    yes I believe it is an MOT failure. Could be wrong though.
  1. How do I remove the light switch assembly?
    By AirCooledHeaven in forum Bodywork & Interior
    Last Post: 13th September 2010, 17:01
  2. Hazard Switch
    By v6boy in forum Bodywork & Interior
    Last Post: 6th March 2008, 13:36
  3. Hazard Warning Light Switch
    By CHRISSMART41 in forum Bodywork & Interior
    Last Post: 17th November 2007, 10:05
2004 opel vectra hazard switch remove
vauxhall vectra 2002 hazard lights not working
hazard light switch
removing a vectra hazard lights relay
astra g hazard light switch removal
how do you remove hazard light switch on a 2006 vauxhall meriva
how do you remove hazard switch from vauxhall vectra c
how to change hazard switch for opel astra h 2005 model
how to remove hazard switch on opel astra h
how can I remove opel astra h hazard switch
remove hazard switch for opel astra h
how to change a hazard switch in an open astra h
how to replace a hazard switch for opel astra h
changing hazard switch for astra h
how to remove the hazard switch on an opel astra
1999 vauxhall vectra hazard warning light switch
Tags for this Thread
