Thread: 1.9 CDTI 120bhp Hesitating
    Regular Member cphaza's Avatar
    Hertfordshire
    Default 1.9 CDTI 120bhp Hesitating
    howdy chaps.
    My 06 120hp cdti is randomley being an ass. When maintaining a steady speed (this can be 30mph or 80, doesnt matter) and then putting your foot down, the car hesitates momentarily,splutters a bit then takes off. It is only ocasional and the rest of the time its a dream, full of power with no problem. I have no eml light and after a plug in no codes were found. Anyone any ideas?
    Sep 2010
    Hartlepool
    I, among others, am currently experiencing similar problems (see my thread entitled "Hesitation whilst driving").
    I own a 1.9 CDTi 150 (But maybe not for much longer - I might get rid of it as it's costing too much money to keep running. Don't get me wrong, it's a lovely powerful engine but mine has this problem and I've already paid a small fortune out on it this year already without this problem).
    Suggestions range from:-
    EGR valve needs cleaning (I only had a new one earlier this year)
    Throttle body needs cleaning (Plan to do this early next week when I get the gasket)
    Boost pressure sensor needs cleaning (Already done last week)
    Vacuum boost pipes perished / split (Replaced last week with 4mm silicone tube)
    Throttle position sensor (Rare occurance)
    HP Fuel Pump on it's way out
    Fuel filter clogged up (Getting changed tomorrow)
    HTH
    Regular Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    Apparently it could also be rattly Dual Mass Flywheel (seem to recall reading in another post).
    Someone did also mention about the 3rd injector wiring connector getting corroded or something causing an occasional misfire (Vx apparently have a modified set of injector plugs)
    I'm in the same situation......... keep throwing money at the blooming thing but still not sorted it yet.
    I replaced my EGR a couple of weeks ago and have read on here that it may be something to do with new version of EGR valve. From what I understand it may be possible to get Vx to upgrade the ECU software to manage the misfirng caused by new EGR. Will be booking my car in, in a couple weeks and see if they can upgrade the software (providing its not been done already),
    First things first though would be to clean out the EGR and Boost sensor (How-To's can be found on here for these)
    Best of luck to you both and hope you manage to get it sorted
    Damo
    Sep 2010
    Hartlepool
    Have just spotted this comment on another thread which may be of use...
    "I found what was generating the P1125 Throttle position sensor error and engine stall/cut out or short power loss on my car. It was a cracked solder joint on the PCB inside the throttle body, on one of the connector pins. This caused the valve to close temporarily. I drove 100 miles now without problems. Took some pictures that I will post when I get home. Easy to fix if you have a solder iron." (User - Andreitone)
    I'm going to check this when I give the throttle body a clean out early next week.
    Here is a link to the thread the comment is from:- http://www.vectra-c.com/forum/showth...37#post1337237
    HTH because, if it helps you and others, it helps me!
    Bristol
    Vehicle : CDTI 150
    Gents with CDTI 120, hope this helps
    Field Remedy: 2149
    Subject: Engine Z19DT/Z19DTL - Jerking in certain rpm range
    Models: Engines: Option:
    Astra-H ...2006,Zafira-B ...2006,Vectra-C 2004...2006 Z19DT| Z19DTL,Z19DT| Z19DTL,Z19DT| Z19DTL only C9 system and 2 valve engines
    Complaint: Customer complaint about engine jerking between 1500-2500 rpm, mostly with 2nd or 3rd gear engaged.
    Cause: Problem is related to a EGR software deviation.
    Production:
    Remedy:
    In case of customer complaint reprogram ECU with an improved software.
    The new software will be available as of CW30/2008 via TIS2WEB
    (version 8.0) (Only vehicles with MY 2006).
    Modified software for Vectra/Signum, MT, with and without DPF,
    as of MY 2004:
    Available as of 27-Jul-2009!
    FunctionalGroup: J - Engine
    Complaint Group: 19 - Poor Engine Driveability
    Trouble Code: None
    Bristol
    Vehicle : CDTI 150
    Those with CDTI 150
    Field Remedy: 1849
    Subject: Engine Z19DT/H - Jerking
    Vectra-C 2004...2005,Signum 2004...2005 Z19DT| Z19DTH,Z19DT| Z19DTH
    Complaint: Customer complains about a kind of jerking at steady state or at slight acceleration.
    Cause: The problem is caused by high EGR-rate in combination with component tolerances.
    Production:
    Remedy:
    In case of customer complaint reprogram the ECU with new software as of TIS 2000-CD, Version 67.
    If the problem occurs with the new software again, contact ETAC for further information.
    Please note:
    A replacement of any parts (injectors, high-pressure pump, EGR valve, ECU, etc.)is not necessary.
    Complaint Group: 18 - Poor Drivebility
    Trouble Code: None
    Hertfordshire
    Thanks for your suggestions peeps, should have pointed out that i have already cleaned the boost/map/egr etc.. as suggested and how2'd on here. Helped in lots of other ways, but didnt cure this problem. Those field remedies are interesting though. What do you think the chances are of me getting VX to do it for nowt?!
    Bristol
    Vehicle : CDTI 150
    Try quoting the FR as its a known issue.
    They may try to get out of it as you should get the software updated at every service with Vx if there is an update available.
    My local dealer charges £60 for a software update.
    If you can find an independent garage that has paid for the link to Vx then they may be cheaper
  1. Help Please - Signum 1.9 cdti 120bhp
    By T111mts in forum Vectra C / Signum Troubleshooting
    Last Post: 17th February 2013, 19:10
  2. 1.9 CDTI 120bhp
    By loopy_kiwi in forum Diesel Engine related
    Last Post: 13th April 2012, 19:33
  3. Cdti 120bhp air filter help
    By 0114NIGEL0114 in forum Tuning
    Last Post: 7th May 2011, 18:30
  4. breeze 1.9 cdti 120bhp
    By chay6684 in forum Vectra C / Signum Car Chat
    Last Post: 21st February 2011, 18:48
  5. HELP!... v6 CDTi hesitating, now EML on
    By Phatty in forum Engine & Drivetrain
    Last Post: 23rd March 2010, 17:23
https:www.vectra-c.comforumshowthread.php119238-1-9-CDTI-120bhp-Hesitating
z19dt p1125
vectra 1.9cdti 120hp problems
vectra 120 cdti throttle body soldering wire
why does my signum 1.9 hesitate when accelerating
vectra c hesitation
vauxhall vectra 1.9 cdti 120bhp 8v no power
vectra c cdti hesitation
do z19 dth 1.9 120bhp
vectra 1.9 cdti 120 bhp loss of power
1.9 cdti jerking
1.9 cdti injector value
common faults with vauxhall vectra 1.9 cdti 120 hp
vauxhall diesel hesitates when throttle
vectra c 2007 1.9 cdti 120 jerks while driving and tries to cut out
why does signum jerk on acceleration
zafira hesitates
astra 1.9 cdti 120 injector problems
vectra c 1.9 cdti 120 bhp low power
vectra 1.9 cdti jerking before hitting boost
vectra c 1.9 cdti 120 misfire
z19dt hesitation
vauxhall insignia misfire at low revs
vauxhall insignia cdti hesitation
